Male/Unisex collars...?
UpiriumUpirium Posts: 728
I only have one male collar and it's in M4 Too Hot To Handle
But it always gives me a lot of trouble. If I have his head tilted in certain ways it warps, and gets really long and weird and the metal/stud areas stretch unpleasantly.
I am using m4 and I need something that will fit M4. NOT GENESIS. Not something Daz specific that I can't use on Poser because DAZ doesn't work on here and I will never use Daz so please do not suggest it.
I don't have any examples of how it screws up other than this attached pic which I regret doing but it was pretty much a joke so please don't take it seriously.
  • Cris PalominoCris Palomino Posts: 12,938
    I was unable to find a product called M4 Too Hot to Handle when I searched. Was it from the DAZ store? Looks like the collar isn't set up so the studs doesn't stretch with the movement.
    I wasn't able to find any male collar, of the studded variety, at the DAZ store.
    BTW, just as Poser isn't the company name, DAZ isn't the software name. I believe you mean DAZ Studio?
  • UpiriumUpirium Posts: 728
    edited November 2014
    Yeah, I meant DAZ Studio
    I thought people would understand ):
    What I'm saying is, I can't use anything that is Daz Studio ONLY. I know there are some things that install to Poser but others don't and I can't use those.
    This is Too Hot To Handle:
    http://www.renderosity.com/mod/bcs/m4-too-hot-to-handle/77446
    (it's a little NSFW)
    I don't even need a studded collar, just a collar.
    Post edited by Upirium on
  • ByrdieByrdie Posts: 1,783
    That set is at Renderosity, the vendor has several "Too Hot" products and I have all the M4 ones and a couple of the V4's too. But I've never known it to do that when posing. Is there a setting checked when conforming it that maybe shouldn't be used? I've only seen warping in such things when copy morphs is used. Also, you might try just parenting it instead.
    There's also a couple of collar sets over there called "Chokies", you'll probably find them if you search for Goth stuff. Says for V4 (at least one does) but since they are props they work just fine on M4 too. Without, I am very happy to say, much tinkering and no distortion at all.
