Skin Problem
RCTSpankyRCTSpanky Posts: 850
I did a render with Lee 6 and have an issue with the skin. It's simply white. I had the same issues with another Generation 6 charcater, but can't remeber which one it was.
I've used only one distant light. Nothing more. Any helpful idea is very welcome.
  • JUJUJUJU Posts: 1,133
    Sometimes I had this error too .... save the file (if you have an older one then use an other name) and shut down Studio.
    Open the file again an try to render then....may be it works....
  • Melissa ConwayMelissa Conway Posts: 590
    I get this a lot with AoA's lights. I just shut down Studio and restart. The file is always fine when I reopen.
    Save your scene, close the scene and then reopen the scene and you should be just fine.
