Zbrush dynamic simulation problem
Hello! Another strange issue I have while trying to use dynamic simelation in Zbrush.
Basically it works but objects never touch the body, the always interact at some distance.
Even if I put object closer once I move it it jumps at that distance again.
By default, the inflate value for the collision volume is set to 1. Try reducing it to something like 0.1 or 0.2.
Thank you! Now it works perfectly.
And maybe you could help me with one more problem.
When I create come clothes in ZBrush I can't fit it to my model, it's parented and rigged, it moves but it placed lower than in should be.
In this example I made a simple swimsuit (just extracted mask), but after Transfer Utility it goes down :(
How did you get the mesh in and out of Daz Studio?
I use bridge, File>Sent to ZBrush and in ZBrush I use button GoZ to send it back. But also you can export it as *.obj file and work with it and then inport it back.
