Clothing is not responding to new morphs
Zantetsukens-cut
So I just converted a bunch of characters from Kids4/Victoria4 to Genesis3 but the first time I tried setting one up for use (Kaitey from K4). I did what always worked years ago. With the morph loaded by her self and slider at 100% also I had limits and auto-follow on as well . I Fitted the rigging to her shape and then did an ECR freeze to lock the modified bone positions and controllers to the current shape. And then saved her as a morph asset. Then I reset and restarted the G3 base model and watched the armature as I slide the morph on and off, and it's growing/shrinking and fa
Follows perfectly. But when I load any clothing item or hair, it will also follow every movement as well but it wont shrink to the shape of the K4 morph. But will still take the shape of other preloaded morphs. Really confused because this isn't me first time doing this but it's the first time I can't make this work. Any ideas?
1st thoughts - did you display the bones for the morphed figure, are they moving with the figure as expected?
For extreme morphs, which any child, baby, monster, etc. would be, it is not uncommon to have to make special clothing morphs into the clothing for them to fit correctly.
For one of the tiny fairy morphs I have, I can get the clothing to follow down IF first I load everything on the normal sized figure, make sure the clothing is all "fit to" - and then select and dial down the figure shape.
Rather than guess what you did or didn't do, here's how I just made one of K4 for G3F.
