Need an Opacity Map for Geoshell *SOLVED*
Fae3D
I'm looking for an opacity map to turn a geoshell of Genesis 8 Male into a bodysuit, with the hands removed and the neck cut like a crew neck shirt. Legs don't matter at all, they can be left as is. I'm trying to make my own, but I'm having a hard time figuring out where stuff is on the torso map.
Has anyone seen anything like this? Or a tutorial on how to make one?
Edit: Apparently you can turn surfaces off on geoshells, so that works fine!
Post edited by Fae3D on
You can set the visibility directly for individual surfaces and individual face groups, and any combination of the two. The hands are unfortunately not a separate surface, but you can set the visibility of the individual face groups that comprise the hand (rhand, rindex1, rindex2, rindex3, etc.). Select the geoshell and look for Shell->Visibility in the Parameters tab.
You could take a look at this and it walks you through how to do it. https://www.daz3d.com/second-skin--the-complete-guide-to-geoshells
Also take a look through the store here. There are a few that you may be able to use. https://www.daz3d.com/catalogsearch/result/?pp=80&q=body+geoshell&s=score&p=1&guid=ce80fa3d-519c-4369-8439-069f74f43cd2
Aha! That's exactly what I needed to know. That will work perfectly, thank you!
Thank you very much for the links!
Don't forget the fingernails (they're in Surfaces)
LOL, good advice, thanks! ^_^
