Genesis 3 to 8 PROPS.
I am aware of scripts that convert clothing, hair and even morphs from Genesis 3 to Genesis 8 both male and female. Is there anything like this to convert props, such as swords, guns, etc?
There are those:
https://www.daz3d.com/props--poses-converter-from-genesis-3-female-to-genesis-8-female
https://www.daz3d.com/props--poses-converter-from-genesis-3-male-to-genesis-8-male
Have a look at RiverSoftArt: https://www.daz3d.com/riversoft-art
Thank you both. These are perfect!
Alternatively...
Load the weapon to the (A pose) G8M figure using the G3M prop pose. Let's say it's a sword held in the right hand. The hand will be closed as if around the weapon, but the weapon is at shoulder height instead of in the hand.
Find the sword in the scene tab and unparent it from G8M's right hand.
Select the G8M's shoulder and bend it upwards by 45 degrees, that's a bend of -45 for the right shoulder. The hand should now be holding the sword, you may need fine tune by moving the sword and/or the hand slightly. Once you're happy with it, parent the sword to the hand again.
Tried this with the G3M Detective poses
https://www.daz3d.com/detective-bundle
Unfortunatly it seems to crash after the 10th pose at line 1330?
Log
2021-09-23 16:06:43.843 DEBUG: Execution Complete.
2021-09-23 16:06:49.506 WARNING: Script Error: Line 1330
2021-09-23 16:06:49.506 WARNING: Error: cannot access member `getNodeParent' of deleted QObject
2021-09-23 16:06:49.506 WARNING: Stack Trace:
<anonymous>()@F:/Users/Public/Documents/Daz 3D/My Library/data/RiverSoft Art/Common/RSPropConversionFunctions.dse:1330
2021-09-23 16:06:49.516 Error in script execution: F:/Users/Public/Documents/Daz 3D/My Library/Scripts/RiverSoft Art/Props & Poses Converter/Props & Poses Converter G3M to G8M.dse
I reset everything and just tried to run the next pose (11th) and the same error occured.
But in the scene G8M did convert but the pose did not save to the target folder?
Tried with the props for the Detective bundle and none of them convert.
Log
2021-09-23 16:59:47.469 DEBUG: END Conversion of F:/Users/Public/Documents/Daz 3D/My Library/Props/Detective/Binoculars.duf
2021-09-23 16:59:47.469 DEBUG: RemoveExtraSkeletons Genesis 3 Male Genesis 8 Male
2021-09-23 16:59:47.594 DEBUG: Execution Complete.
2021-09-23 16:59:51.117 WARNING: Script Error: Line 1330
2021-09-23 16:59:51.117 WARNING: Error: cannot access member `getNodeParent' of deleted QObject
2021-09-23 16:59:51.117 WARNING: Stack Trace:
2021-09-23 16:59:51.128 Error in script execution: F:/Users/Public/Documents/Daz 3D/My Library/Scripts/RiverSoft Art/Props & Poses Converter/Props & Poses Converter G3M to G8M.dse
The save option spits out an error message but seems to still work?
Not sure if that is a factor.
Just load the prop and not have it Fit-To the figure instead parent it to the hand.
I got this script to help automate all that both props & poses.
