Transferring morphs from G8F to G8M?
Is there an (easy) way for transferring morphs from G8F to G8M?
    edited September 2021
    Ok I'll jump in here. No. {see post below, sometimes it's nice to be wrong :-) }
    There are some conversion utilities, there are some work-a-rounds but bottom line, it's a lot easier just to buy the morphs for concerned figure in the first place ;-)
    The thread to be following is here: Click here.
    Post edited by Catherine3678ab on
  • VisuimagVisuimag Posts: 578
    There's a way, but it isn't quick (depending on how many morphs you want to do).
    The procedure is easy, however. Open the Transfer Utility, select the figure you want to transfer the morphs from (make said morphs a Favorite in the Parameters Tab first → this is important). From there, choose the Clone option (for example — if going from G8F to G8M, you would choose the Genesis 8 Male Clone). After that, select the figure the morphs are going to and then click Show Options.
    In there, check Use Near Vertices and make the number 1000%. After that, uncheck Weight Maps, Selection Map, Face Groups, and Region Groups, but leave Morph Targets checked. To the right in the Morph Targets Tab, Change From Source from None to Favorites. After that, uncheck From Projection Template and Override Existing. Down below, you will also uncheck Parent To Source Figure and Fit To Source Figure and click Accept. Your morphs should now be applied to the new figure.
    Post edited by Visuimag on
    Okay ... that's something to try, thanks :-)
    Yup! Let me know how it goes!
    It went well - on the 1st try even :-)
    Following your instructions I also:
    In my usual fashion, loaded into the scene both G8M and G8F, removed all eyelashes and set figures to base resolution, render subD Level 0, and I leave subD level at 1 [1 or 0, either setting normally lets morphs be created].
    Dialed in what's likely a popular morph for G8F.
    Set that morph into the Favorite Category by clicking on the little heart.
    On the Transfer Utility, ? "remove unused bones" I unchecked that box too.
    Clicking on Morph Targets to get the extended options dialog for it, From Source "Favorites" - unchecked the other 2 boxes.
    Post Transfer Options: uncheck everything.
    Click Accept.
    It took. Dialed in morph, returned figure to high res etc. Polished morph and saved it for in case I ever want to have what was referred to as a "nursing father" for some Biblical scene.
    1006 x 805 - 100K
    1558 x 815 - 432K
    edited December 2021
    In trying this procedure in D/S4.16 with a full character shape morph, when matching the rigging to figure, the mesh VANISHED. It is not supposed to do that. So I went ahead with the steps like it was still there and saved the alleged morph on the awol mesh. Reloaded the scene, the morph WAS THERE but the rigging had NOT adjusted. So I asked again for the rigging to be adjusted and it was. ERC freeze worked too. Resaved morph. Reloaded scene.
    Nothing is always as simply as one expects/hopes it is or should be. In the new morph there was a serious glitch so an adjustment morph was made to take care of that.
    Update: and then for unknown reason D/S claimed the duplicate error message when loading a new figure. Sigh.
    So back to drawing board: Got it working finally.
    Tip: Before telling D/S to adjust rigging to shape, "save the morph" ... then adjust rigging, do ERC, then save the morph again. Apparently there are times when the rigging is what may cause serious glitches in the newly morphed figure, so I made an adjustment morph but this time instead of having one dial the other in [and then get duplicate error messages], I remade the morph A with B, and saved the final working morph. It now loads as it should and I have a male and female Drax figure. And there will be no .pdf tutorial on how to do this.
  • That sounds as if there were two ERC Freezes - before you can do an ERC Freeze for adjustments to the first round of settings you must right-click on the link in the Property Hierarchy and select ERC Bake, with the controller set full on, so that you are working with raw not linked values.
    After the adjustment morph, I did not need to have another bone adjustment, while the rigging threw out some geometry there was no bone on it. Adjustment morph was just to put a bit of mesh back in the mouth where it belonged.
    For each morph there was only the one adjust rigging to mesh, one ERC freeze.
    I repeated each morph with either a fresh scene or a fresh instance of D/S.
    Each time I asked for an Adjust rigging to mesh [for new unsaved morph], the mesh vanished and/or the viewpoint became a void, nothing but the background colour. The rigging did not adjust.
    After saving that morph from an apparently blank scene {so G8M had to be in there somehow, just in the um, ethereal realm I guess}, clearing the scene and/or starting D/S afresh, loading in G8M - then the saved morph was there and working. Then I could run the Adjust rigging to shape and it worked. Then I ran the ERC freeze and that worked, then I would resave the morph.
    So, one brand new morph saved, then Adjust rigging to shape, then ERC freeze and then save again.
    Merry Christmas Richard!  I put in a ticket too so them with larger computer systems might know to take a look at those features and at least be aware of them and like, maybe fix that.
    So far with all my morphs I've never had to use ERC Bake. Mind you, so far I've never had a morph when rigged, throw the upper palette and part of a couple of teeth down through the jaw about a foot.
    So for future reference, IF I ever want to do a 2nd ERC freeze to a morph, then I must first bake it as you say. Noted. Thank you.
    1000 x 1000 - 564K
  • lioncrudlioncrud Posts: 29
    is there a new method? this seems outdated and does not work.
  • crosswindcrosswind Posts: 9,538
    Transfer with Morph Targets + Clone always works...and you don't need the option of Use Near Vertices because you use no projection.
    After transfer, you just further dial G8F Clone on G8M... so as to have 100% same shape on G8M with the transferred Head / Body morphs dialed. Then you can further export the full character morph to OBJ, Zero G8M shape, load a HeadSplit DFormer on G8M, and import OBJ with Morph Loader Pro to separate Head / Body morphs again.
    Alternatively, you can use Fit Suit method  >  https://youtu.be/kXssz90XFEA?si=FyjrKwAaHXlxMVDB
  • teechurz_7c41d96282teechurz_7c41d96282 Posts: 113
    edited November 2
    I have been trying this all day to no avail.  I'm trying to transfer a head morph from G8M to G8F and put all the settings just like stated above (and even tweaked a few to see if that would help), but the head morph just will not appear in the G8F model.
    All my settings are identical to Catherine's above (but reversed G8M with G8F figures and their respective clones).  The head morph is not an HD morph (as far as I can tell).
    Any suggestions?
    1075 x 1486 - 339K
    Post edited by teechurz_7c41d96282 on
    edited November 3
    Any suggestions?
    1stly, what you want to transfer needs to be a Morph, check if it is in its Parameter Settings > Owner. 2ndly, make sure you mark it as Favorite.
    BTW, even with an HD morph, you should be able to see it on the target figure after transfer... only HD deltas won't work ~~
    Post edited by crosswind on
