mcjTwinQuadPlateOnePipe: morphing prop, thick pipe & two 4-bolts plates
mCasualmCasual Posts: 4,607
edited November 2014 in Freebies
right here -------> https://sites.google.com/site/mcasualsdazscripts4/mcjtwinquadplateonepipe
( then i guess ... someday ... i will make a 90 degrees tube , the 45 degrees one, the T's abd the crosses )
Post edited by Cris Palomino on
  • Charles WestCharles West Posts: 123
    Of course if you are looking for golden ideas....
    600 x 600 - 52K
  • mCasualmCasual Posts: 4,607
    edited October 2014
    actually i'm trying to conclude the series of props ! to return to the planar-mechanism animation script,
    then return to the mildly-awaited projects i started :)
    for example, the physics simulation services
    1920 x 1080 - 812K
    800 x 600 - 875K
    Post edited by mCasual on
    edited October 2014
    there's 16 mounting hole edges
    each edge has its own radius, sharp, AwayX and AwayZ morphs
    that's 64 morphs
    but i also added 4 controllers that let you control the sharpness, radiusness and Away'ness of the 16 holes in one shot!
    the 16 corner edges will have the same complement of morphs and controllers
    figure 2 is from the the-making-of
    it shows 2 cylinders used to isolate the corner-edge vertices
    then a script, which i may someday publish, creates a Sharpen, AwayX, AwayZ and Radius morph
    1920 x 1080 - 543K
    1920 x 1080 - 309K
    edited October 2014
    note
    here http://www.thingiverse.com/thing:257091
    there's 3d objects in STL format, intended for 3D printing
    some if not all are under the Creative Commons Attribution, Share-Alike license
    Blender among others, with the proper plugin which i think is present in the standard blender can import STL files
    and Blender can export in .obj format, which Daz Studio can read
    so ..... lets try it
    i downloaded the thingverse zip file
    unzipped the Flanged_Cross.stl file it contains
    it's 800KB
    i open blender
    i delete the default cube
    i do a file / import / stl
    see fig 1 - 16000 facets, not too bad
    i do a file / export / obj
    then in daz studio i do a file/import obj
    unfortunately it's triangulated
    but it's there !
    the texture mapping is unusable, which is a good reason for you to get acquainted with mcjBoxUV
    1920 x 1080 - 519K
    864 x 782 - 233K
    1118 x 588 - 152K
    edited October 2014
    we're talking more than 144 morphs ( 4 morphs per hole edge, 2 edges per hole, 2 plates, 4 holes per plate plus the pipe )
    so the shape can be used to make complicated excentric legs and funnels and what not
    but thanks to banded controls ( ERC Links ), the standard pipes can be obtained with a few adjustments
    it's almost ready !
    turns out i have 2 things to fix
    the pipe's inner rims are not perfect quarter-of-a-circle
    the prop exporter doesnt export the ERC Links
    ( i know how to do that )
    1920 x 1080 - 1015K
    1346 x 781 - 556K
    1920 x 1080 - 759K
    1920 x 1080 - 468K
    1920 x 902 - 503K
    edited October 2014
    at the last minute i discovered the inner pipe rims were imperfect
    but that will be fixed
    expected release tomorrow !
    ( and who knows maybe tonight )
    the "flattenizing" rings put a stop to the curve of the pipe "lip"
    this makes the top surface look very flat and the pipe tunnel look very straight
    ( those 2 terminating thin rings have the same normal as those 2 surfaces )
    1920 x 1080 - 414K
    1920 x 1080 - 171K
    1920 x 1080 - 998K
    1850 x 684 - 241K
    edited October 2014
    oh my Bob the release is so close !
    1920 x 1080 - 722K
    1600 x 800 - 349K
    1600 x 800 - 353K
    1600 x 800 - 356K
    1600 x 800 - 352K
    Thanks again for all the great work.
    thanks for the encouraging words!
    i just have to make a quick google site page and post it
    once that's done i think i'll get back the the machine animation script
    800 x 600 - 121K
  • RAMWolffRAMWolff Posts: 10,394
    Looks really good there C! Add in some morphs to the bottom to round and you have a lovely cafe table. Uh minus the holes at the top! LOL
    edited October 2014
    readyyyyyyyyyyyyyy ! oh yay :)
    if you downloaded the prop in the 5 minutes following release
    the mychrome texture was missing
    but now it's there
    note that for the promotional image i used a texture like that as the reflection map
    1536 x 1536 - 354K
    455 x 455 - 80K
    edited October 2014
    eventually i plan to post the 6 recent props without the mounting holes
    it will reduce the "weight" of the geometry and the prop itself
    and anyway most of the time the mounting holes are hidden under bolts
    also i may make versions with disk flanges
    though this prop's mounting plates can be made almost round by using rounded-corners with an extra large radius
    hmm could be.......
    600 x 600 - 142K
    NICE! :-)
    i looked at it too quickly back then
    turns out the cylinder i was thinking of only has 1 squary plate hmm i can try ...
    634 x 401 - 65K
  • TheCastellanTheCastellan Posts: 711
    Neato. You make better stuff than the commercial modelers, it seems. :D
