• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Making characters look natural with a single sun light (not like ghosts)
jamesramirez6734jamesramirez6734 Posts: 90
September 2021 edited September 2021 in Blender Discussion
In Daz Studio with the 'Sun/Sky only' Iray settings, it's extremely easy to very quickly get a natural looking render of a figure.
In Blender with Cycles and a sun light, whatever I do the render always seems to have a sepia-like filter over it, as if the characters are appearing as ghosts.
I can't seem to achieve a warm naturally looking skin - if I reduce the strength of the sun it makes the model too dark. The skin always has that slightly angelic whiteness as if the image has been drained of colour by a filter.
I know I can't match Iray exactly, but does anyone have any ideas for achieving a more natural 'warmer' look which is closer to Daz? I'm using Diffeomorphic which is great btw.
Post edited by jamesramirez6734 on September 2021
  • TheMysteryIsThePointTheMysteryIsThePoint Posts: 3,251
    September 2021
    I noticed that your sun is just a white light, try the Starlight & Atmospheric plugin, or the Sky Shader included with Blender.
    You didn't show your node setup for the skin, but it looks like you don't have any SSS, or it is too low.
    And I don't know if this is still true with Diffeo, but two things:
    1) You used to have to make sure you were in Render View with Cycles selected instead of EEVEE when you did the import, in order for the materials conversion to work best.
    2) There were two ways to convert materials: via the Principle BSDF, or via Diffeo's node setup. I can't remember how to select one or the other, but for maximum fidelity you want to use Diffeo's node setup, not the Principled BSDF.
  • brainmuffinbrainmuffin Posts: 1,276
    September 2021
    Yeah, I don't know if it is still necessary to switch to Cycles rendering before importing, but I still do. I can't seem to make Blender understand I want Cycles by default.
  • PadonePadone Posts: 4,023
    As for diffeo it is not necessary to switch to cycles or eevee before importing. The material conversion will be determined by the material options in the global settings. As Donald reports, bsdf is better than principled as iray conversion, because the principled shader is limited compared to iray. But the bsdf conversion will not work fine with eevee, because eevee too is limited compared to iray. So if you want to use eevee then the principled conversion is better.
    • bsdf: faithful iray conversion, intended to work fine with cycles
    • principled: approximated iray conversion, intended to work fine both with cycles and eevee
    As for the gray skin it may also depend on the dual lobe fresnel effect, that is not exactly the same in blender. So you may try to decrease the fresnel in blender to get a more natural skin look.
    https://bitbucket.org/Diffeomorphic/import_daz/issues/656/skin-difference-between-blender-and-daz
    edit. Personally I suspect that the fresnel in iray is white, that is, it doesn't reflect the environment. But that wouldn't be physically accurate. Or it may be a bug in the daz uber shader. Didn't have time to do deep tests so this is just a wild guess.
    Post edited by Padone on September 2021
    September 2021
    Hi @Padone Can you please clarify this? I'm unclear which options this is referring to, and where they are.
    It's in the global settings, you can choose the material method independently for solid, sss, refraction and hair.
    453 x 163 - 21K
    September 2021
    @Padone Oh, you ment Diffeo's global settings, not Blender's. Found it, thank you.
  • jamesramirez6734jamesramirez6734 Posts: 90
    September 2021
    Thanks all. Looks like I have no SSS method in my global settings Materials section (Method and Refactive are there) - is there something which needs to be configured to get it to appear?
    September 2021
    you probably need to update
    September 2021
    Ah good spot!
    New update functionalities look great. Not sure 1.6 is quite ready for release though as I get several white specs on the model's face which weren't present with 1.5
    September 2021
    you can report bugs at bitbucket
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
