Eyeball prop?
StorypilotStorypilot Posts: 1,683
I'm looking for an eyeball prop, preferably one that uses the DAZ figure eye texture UVs, though not a deal breaker. Also cool if it has the optic nerve or eye muscles attached, but also not a deal breaker.
Alternatively, is there a simple way to pop the eyes out of Genesis or G2 and get rid of the rest of the geometry? If I have to, I'll go the route of making all the rest of Genesis invisible, except the eyes... but my intent is actually to have a lot of eyes duplicated all over the place, so I'd rather not have them all attached to invisible Genesises.
I thought for sure there'd be one in the anatomy bundle, but no.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,850
    if you do that export an obj of it with ignore invisible nodes
    then reimport the eyeball
    it will load textures the same
  • StorypilotStorypilot Posts: 1,683
    oh, that's perfect, thank you wendy, I'll try it now.
    meantime, i'd still be curious if anyone does know of one with the muscies/nerve attached :)
  • MegonNoelMegonNoel Posts: 386
    edited October 2014
    Thank you MegonNoel, that is a good one. I downloaded it and it may work for when I want the icky parts attached. :)
    Meanwhile, I've been working on wendy's suggestion, and after some doing got it to work the way I wanted it to. I was able to get the eyeball by itself following those instructions right away, but it was trickier getting it to where it would take genesis 2 eye textures easily. I could manually apply the maps, but it had changed the surface names in the export/import. After a few adjustments (unchecking "write material library" but leaving "write surfaces" checked was what did it), the export kept the surface names, and the reimport then accepted materials from presets. Then I got its rotation fixed so it was rotating on its own axis and not around an imaginary genesis's foot level, and got it saved out as a prop that would identify itself as compatible with genesis 2 textures, so it's even easier to deal with now.
    Thanks again Wendy. It's a perfect little solo eye, except that you can only use it from front and frontward-side angles, it doesn't have geometry at the very back. I think between these two solutions, I'm covered, though I haven't tried out the freebie one yet.
    440 x 365 - 75K
    Post edited by Storypilot on
