Is there a card that can do TWO renders at once?
Griffin AvidGriffin Avid Posts: 3,863
edited September 2021 in The Commons
[Is there a card that can do TWO renders at once?] Or is it a core thing?
In the past I have accidentally started or run two renders at once. Sometimes it works, sometimes it crashes,
I remember reading somewhere that Daz uses the same SAME memory pool for every render so it *should* be technically impossible.
BUT! There's a script to run two Daz sessions at once...and they run in separate threads.
So if they are running into two threads, can they render across resources- long as nothing maxes out?
NVIDIA RTX A6000 GRAPHICS CARD
Wondering at the potential of this card....
  • I have rendered with Carrara Octane AND DAZ iray simultaneously on my 980ti cheeky
    so I guess it comes down to can you run two versions of your program at once and will it fit.
    AFAIK D|S you cannot (and since I only have one Octane license I can only have a single instance of that too)
    not sure with your script though
  • kyoto kidkyoto kid Posts: 42,318
    ...hmmm that would be a good case to seve up the zlotys for the A6000 or maybe dual NVLInked 3090s
    Post edited by kyoto kid on
  • GordigGordig Posts: 10,758
    I've done multiple Iray renders simultaneously....before I had an Nvidia card.
  • I've done multiple Iray renders simultaneously....before I had an Nvidia card.
    But just -  NOT in Daz Studio. I sorta gather....
    What's strange is that I've NEVER been able to get an Ray-tracing render to work in anything but Daz.sad
    No, in DS. I used to keep two or even three instances of DS open, working on different scenes, and sometimes they'd all be rendering. I don't use Iray in C4D, which is the only other 3D program I use to render. I haven't bothered to check whether Cycles 4D uses my GPU.
    Make sure you liquid cool those 3090s, they can get really toasty at full load
    ...OK, maybe a pair of A5000s, their TDP is only 230w.
