mcjQuadPlateOnePipe - Morphing prop thick pipe and 4-bolt holes
mCasualmCasual Posts: 4,607
edited October 2014 in Freebies
>>>>>>>> https://sites.google.com/site/mcasualsdazscripts4/mcjquadplateonepipe
after that will come the mcjQuadPlateCylinder
and versions of recent props with no bolt-down holes
Post edited by mCasual on
  • SzarkSzark Posts: 10,634
    I am loving these new props. Thanks for sharing again and again and again. :)
  • mCasualmCasual Posts: 4,607
    edited October 2014
    welcome, it's great to know someone uses them !
    List of morphs for the pipe
    Pipe Int Radius,
    Pipe Move Z,
    Pipe Move X,
    Sharp Pipe Int Bot,
    Sharp Pipe Int Top,
    harp Pipe Ext Top,
    Sharp Pipe Ext Bottom,
    Pipe Radius,
    Pipe Up,
    800 x 600 - 54K
    552 x 524 - 120K
    641 x 641 - 120K
    Downloaded and yes I will use props like these. Been a few times already I could have used things like this.
  • McGrandpaMcGrandpa Posts: 464
    edited October 2014
    Oh wow. What you have created is called a FLANGE in the world of Industry! They can have from two to x number of bolt holes, or none. If none they are a slip fit or butt fit. Slip fit is left square on the end and can be sweated or welded to pipe slipped inside. A flange with a long long neck becomes a trunnion depending on use. While simple, you made it so well I think you must be a Pipefitter or some related Craft!
    I'm sorry there is no Poser usable version though. :(
    McG.
    Post edited by McGrandpa on
    edited October 2014
    McG.
    in fact all the props on my site are supposed to be Poser props
    there must be a dozen mechanical props by now
    though i didn't test many of them in poser
    lets test this one in poser 9 ...
    yes works fine !
    the props are distributed as zipped Runtime folders so all you have to do is unzip them in a Poser Content folder
    i didn't work in pipe fitting , but i guess the interest is from drafting courses when i studied for architecture
    i'm mostly into programming and electronics ( E.Eng )
    i did not recently update the thumbnail index https://sites.google.com/site/mcasualsdazscripts4/
    where most of the props are shown, so you have to check in the left-side menu for
    mcjQuadPlate and the other new ones
    852 x 750 - 226K
    Well I shall go back and download some and see how they work in P2014 from my runtime on an external (to Poser) drive. I have a mess of HD's in my desktop. One 1TB drive is devoted to the wonderful stuff we love to call *CONTENT* ! Heh! Oh I am loving my toys today! :o)
  • ElowanElowan Posts: 388
    TYVM!!:coolsmile:
