Has anyone rendered Daz Iray with Google Colab?
[Has anyone rendered Daz Iray with Google Colab?] Anybody ever find a workaround for this? Just curious, as right now I'd still quite honestly prefer to render things quickly in Daz than export them to Unreal or even Blender. Getting Daz-to-CC3-to-Unreal hair materials working properly is an absolute nightmare; I wasted hours to guesswork regarding hair opacity and blend mode today and I achieved nothing in the end.
Please put your question in the post body and the title - Daz 3D Forums
What is Google Collab if I may ask?
Good question.
There are three problems that are going to arise with this idea.
1. you can't run DS directly on it, as collab is linux based. Might be able to run it through wine, but then there's problem two.
2. DS doesn't(afaik) run "headerless". That is it's setup to run with video output and you'll encounter the same problem bishbosh's video was talking about with EEVEE.
I've read various threads about, trying, to run DS on various cloud services and they kept running into the "DS requires Opengl 1.3" error message.
3. Resource availability.
As this service doesn't allow you, afaik, to set the resources you can use, in "free" mode, you might not be able to render when you need to.
I'd recommend looking into one of the various, paid, render farms, as it's significantly easier to setup and use.
They can get very expensive, very quickly, though.
You could easily hit the, currently inflated, cost of a 3090 in just a few months.
Jack tomalin(the awesome PA) has a render farm service, not much, but is pretty affordable.
http://www.jacktomalin.com/iray/
For the Collab option, might want to invest in IRay server, with a floating license, as it can run under linux natively and can run headerless.
Runs $395/yr.
Might take some finagling to get it working(well outside my realm of expertise), but i'd say it's possible.
