Best female for runway model frame
in The Commons
Hi. I've used the base female, and looked through a lot of the female avatars, and to me it seems like I can't find one that looks like a runway model. Increasing the emaciation slider doesn't really give what I want. They all seem to have some plump whereas I'm looking for something a little lankier. As an example, I'm looking for a frame like Malika el Maslouhi. Are there any models that have a body like hers?
thanks.
https://www.daz3d.com/genesis-8-female-body-morphs
https://www.daz3d.com/the-fashion-model-hd-for-genesis-81-female
If you are ONLY looking for runway type poses that won't push the ancient Victoria 3 based joint geometry beyond what it can cope with, this V3 based but standalone model is old fashioned runway fodder: https://www.daz3d.com/glamorous-vicki-set-for-victoria-3-0. Because it's a standalone figure, and not a morph of V3, alternative clothing is pretty limited, though dForce draping helps these days. To show the figure can be updated to IRay and provided joint limits are observed it can look pretty decent: https://www.renderosity.com/rr/mod/gallery/older-figures-updated-/2936479/.
Beyond fairly limited joint ranges, it's probably better to use a much more sophisticated G8F character. There are a few. For an Easter European vibe, Anastasia. Legs can be lengthened if need be: https://www.daz3d.com/anastasia-for-genesis-8-female
Then there is the very, very leggy and slender Aniyah: https://www.daz3d.com/aniyah-for-darcy-8
The Aniyah body with different head and texture can make any character into a runway model, like this one: https://www.renderosity.com/rr/mod/gallery/show-us-yer-muscles-girlie/2925860/
Aniyah is the only one I can think of aside from the alreay mentioned fashion model.
I too had to think of Aniyah.
This character is kind of lanky https://www.daz3d.com/mieko-for-genesis-8-female I have a morph set that has a lanky morph, I think it's EmmasndJordi. In general, if you play with height morphs, make legs longer, make breasts smaller and use the weight or thin slider, not emaciated you can easily get a model look.
Josephene 8
I'd suggest looking at Genesis 3 figures instead of Genesis 8 ones. Model proportions are way more common for figures from that period.
Maybe try to convert them to G8, if you really want to use some G8 features.
G8.1 features would be a bit more problematic, I haven't seen any automated conversion method from G3 to G8.1 or G8 to G8.1 yet, so the new expression system, as well as the new UVs and their material sets won't work.
Huh? Just use XTransfer or RiverSoft´s converter for G3 -> G8.1
G8 -> G8.1 doesn´t need any conversion.
Everyone's opinion differs, so just buy the V8 morphs and the Killer Legs morphs and make her the way you want. I would start with Victoria 8.0. I find that she is compatible with most poses, as she has been DAZ's "standard."
https://www.daz3d.com/genesis-8-female-head-morphs
https://www.daz3d.com/killer-legs-2-0-morphs-for-genesis-8-female
Secondcircle's older characters always had that thin, model look. Try karen https://www.renderosity.com/rr/mod/bcs/sc-karen-for-g8f/122065/
Arabella 7 is the model thin frame you probably want. https://www.daz3d.com/arabella-7
She is Genesis 3, but can be converted to 8. If you are not into her skin, then that makes it even easier as you only need to convert her morph. Keep in mind HD morphs cannot transfer, so don't get the HD Add On unless you want to use the Genesis 3 outright. Genesis 3 does have a lot of skinnies. But you should be able dial in Genesis 8 with various morphs. Use the thin morph on some other character instead of the base for example. You can make Victoria 8 model thin with some morphs. Fairy type characters are always on the thin side. Karyssa 8 is SUPER thin, maybe even too thin. If you think her hips are too thin, just use a dial that adjust hips. There are tons of fairy and elvish characters for Daz. Some of the Asian characters by Rarestone, CrocodileLui, and others are pretty thin as well. Some my have toonish faces, but they have the model body, you can use any face. Some of the anime like characters also fit this mold.
Sometimes the promo pics don't really convey how thin a character is. There are plenty of characters that are super thin, but it isn't really obvious in their promos. Karyssa is great example. You can probably tell she is thin, but it isn't until you place her in a scene with other more normal characters that you see just how thin she is. I've bought several Asian characters and have been surprised how thin they are compared to others.
If you need more defined features, several HD morph packs will add them.
Stepanida, Noemi, Misumi, RY Alison, Evangeliya, and RY Adeline are great characters and combine pretty well together too
https://www.daz3d.com/ry-adeline-for-victoria-8
https://www.daz3d.com/ry-alison-for-victoria-8
https://www.daz3d.com/evangeliya-hd-for-genesis-8-female
https://www.daz3d.com/stepanida-hd-for-genesis-8-female
https://www.daz3d.com/misumi-hd--signature-smile-hd-expression-for-genesis-8-female
https://www.daz3d.com/noemi-hd--smile-hd-expression-for-genesis-8-female
They are all very tall like supermodels and while some might be more athletic than you're looking for they combine really well and I'd get face and body morphs too like others said
The measurements of the ideal runway fashion model are 72 inches tall and 32-22-33.
The measurements of the ideal Victoria's Secret model are 69 inches tall and 34-24-34.
I used Measure Metrics to make my figures these exact dimensions (don't ask me how - I don't remember).
The chest of the fashion model will likely be somewhat flat, but if you make her torso narrower, you can dial in a few inches of breasts so that the circumfrence of the chest is still 32 inches.
Here is an iimage of Genesis3Female with the ideal runway model measurements. The 2nd image is the same figure, but I made the chest narrower to balance them with the width of the hips, and added a few inches of breasts.
The head morph is 100% Chara. The hair is Chace. The skin texture is Brittany with the translucency lowered. The clothing is the Dance Gear leotard. The third image is the 2nd image model wearing the Ghost Bride outfit.
This body is just the base G3Female body with no character dialed into the body. I just altered the chest-waist-hip measurements. There are some really great products in the store for shapiing body parts - such as https://www.daz3d.com/killer-legs-morphs-for-genesis-3-female-s
If you want a figure that looks like a model in a fashion illustration, my choice would be Aiko 6.
Carboncrow has several fashion model types too https://www.daz3d.com/carboncrow
