Z Miracle of Life Shape and Poses - solved
Bella
Hello,
I'm having a problem with this item
the poses work good but I'm unable to load the shape
in the shaping pane I can see the level gets to 100% after loading the shape but the figure doesn't change at all
I have the Required Product Genesis 8 Female Body Morphs
So.... what am I missing?
Thank you very much :)
Post edited by Bella on
I solved it searching in the forum for issues with other shapes
and the solution was to manually install Genesis 8 Female body morphs
i copy past what suggested in this thread
https://www.daz3d.com/forums/discussion/384386/help-genesis-8-female-body-morphs-not-working-solved
this must be done with DAZ|Studio closed
it worked, after doing it the Z item works perfectly!
Hey! So I'm trying to do that myself, and I still can't get it to work. Any chance you could describe what you did a little bit more? I'm sorry for asking this, I'm just terrible at finding these things. Any help would be greatly appreciated!
Edit: Sorry I just realized the required product. oof
There should be no reason to move the morphs if you installed them correctly in the first place with either DIM (preferably) or Central.
I swear it all went like I said, correctly installed but not working
Sorry! I didn't see it before!
Slightly unrelated, but the pregnancy morph is changing the height of my character. It's even doing it for the default Gen 8 model. Anyone else have this issue or is there something quirky about my files?
