Z Miracle of Life Shape and Poses - solved
BellaBella Posts: 453
Hello,
I'm having a problem with this item
the poses work good but I'm unable to load the shape
in the shaping pane I can see the level gets to 100% after loading the shape but the figure doesn't change at all
I have the Required Product Genesis 8 Female Body Morphs
So.... what am I missing?
Thank you very much :)
Post edited by Bella on
  • BellaBella Posts: 453
    I solved it searching in the forum for issues with other shapes
    and the solution was to manually install Genesis 8 Female body morphs
    i copy past what suggested in this thread
    https://www.daz3d.com/forums/discussion/384386/help-genesis-8-female-body-morphs-not-working-solved
    • Download manual install file from your Product Library page
    • Unpack it
    • Copy the morph files in the /data/ folder into the matching folder in the Connect installation, overwriting the existing files
    this must be done with DAZ|Studio closed
    it worked, after doing it the Z item works perfectly!
  • Mushy MellowMushy Mellow Posts: 8
    edited September 2021
    Hey! So I'm trying to do that myself, and I still can't get it to work. Any chance you could describe what you did a little bit more? I'm sorry for asking this, I'm just terrible at finding these things. Any help would be greatly appreciated!
    Edit: Sorry I just realized the required product. oof
    Post edited by Mushy Mellow on
    There should be no reason to move the morphs if you installed them correctly in the first place with either DIM (preferably) or Central.
    I swear it all went like I said, correctly installed but not working smiley
    Sorry! I didn't see it before!
  • Slightly unrelated, but the pregnancy morph is changing the height of my character. It's even doing it for the default Gen 8 model. Anyone else have this issue or is there something quirky about my files?
