• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
How to perfectly merge the Gen UV Map into the original UV?
acdum1857acdum1857 Posts: 105
August 2021 in Blender Discussion
I am using Genesis 8.1 + additional Nipple and Genitalia.
(and Diffeomorphic)
In Blender their textures are displayed fine, but the UV maps are separate.
So, I want to combine the UVs of the Nipple and Gen parts into the original Torso UVs.
After selecting Nipple and Gen UV, I tried the following, but there was a problem.
* Merge by Distance : topology inside UVs is messed up
* Stitch : The original UV is deformed, and the anus part is divided in half, so the mesh is stretched
How do I perfectly merge the Nipple and Gen UV maps into the original with no original UV deformations or errors?
  • PadonePadone Posts: 4,033
    August 2021 edited August 2021
    setup > finishing > merge uv layers
    advanced setup > materials > collapse udims
    Post edited by Padone on August 2021
  • acdum1857acdum1857 Posts: 105
    Thanks for the reply. Nice to see you again Padone! :D
    After collapse udims, it became like the image on the left.
    Actually I want to merge the UVs like the image on the right.
    However, in this image, they are simply UV moved (G-X-1), not merged.
    Even these vertices are slightly mismatched.
    In this state, I select the seam vertices of Gen UV and run 'Merge by Distance', then they become one UV, but a fine flush occurs at this seam.
    So, I want the below:
    1) As in this image, Nipple and Gen UV fit together with Torso UV to become one UV,
    2) At the same time, no flush occurs on the mesh
    I'm still looking for a solution, but haven't found one yet...
    1286 x 1440 - 2M
    2309 x 2686 - 1M
    Post edited by acdum1857 on August 2021
    As I understand it, with collapse uv you can see the torso uv map alone if you select the torso. Then you can merge or edit seams as you like with the uv editor. Odd that there's any though.
    August 2021
    I figured out the cause of the problem.
    The problem was the wrong material assignment!
    After merging UVs, I removed the existing UVs, and in this process, materials were automatically reassigned and a flush occurred.
    I wasn't expecting the material to be automatically reassigned.
    Thanks for your help. laugh
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
