I need a set of eyes.
AgitatedRiot
Can you tell the difference between these renders?
Post edited by AgitatedRiot on
AgitatedRiot
2nd one is a little more blue. Possibly marginally more saturated.
The first one is a Daz render with some postwork in Photoshop. The second one is Daz to Photoshop Bridge with the same postwork. I like the second one, but still lacking with more thought and more learning, I think I can make it work.
your grasses are distributed differently
load both into photoshop. then copy one and paste it onto the other as a new layer. Either use the "difference" layer blend option on the upper layer to see the differences, or simply do the 'blink camera" trick by turning the top layer visibility off and on, and watch for the change.
In this case there is a difference in height/position or a slight change in camer angle in the seocnd imagfe as the grassy hills appear higher than in the firat one. Also a slight color/tone shift (warmer??)
Different focal length and probably take and slightly different elevation. Open both in individual tabs in your browser and switch back and forth between them to make it easy to notice.
I'm redoing the test renders from the same cam this time no post work. I notice Daz uses Iray while Photoshop uses OpenCL.
I don't really see much of a difference between the 2.
Diffference between those two images and the difference inverted to make it more visible.
Interesting
As a sidebar comment AgitatedRiot could i ask how you got the bridge to run.
There are so many unanswered quieries on here regarding Photoshop Bridge not working and im sure im not the only one to ask.
thanks in advance
