Full Abandone Land Environment for DAZ Studio and Poser!
Gendragon3DGendragon3D Posts: 177
edited October 2014 in Freebies
Hello to all!
Here are links to my new freebie!
They are saved separately for DAZ Studio and Poser Pro 4.6 (DSON Conversion). I have however, Poser to know whether it will work,
but I created a support for DAZ CMS.
I hope you enjoy. Are all welcome!
A brief description of the product:
Product Name: Abandoned land
Product ID: F3D_abandoned land
Artist Name: Freedom3Design (Here, I am known as Gendragon3D)
Product Data: October 15, 2014
He Describes in detail elaborate scene in ZBrush
as well as textures with resolutions up to 4096 Pixels!
Ideal for romantic scenes, fantasy, one near the place of farm
rest for the peasant, the refuge, finally, many possibilities for
you create your own surrender!
I added two textures for the leaves and grass.
A diorama painted in ZBrush that has a pleasant Atmosphere is Also added in the the scene shown in the promos.
Lights created especially for this scene.
Requirements:
The support file was created for DAZ Studio.
Convert Dson if used with Poser.
(you must have to use DSON Importer into Poser).
It's my first conversion is done Poser, hope it works!
Let me know if I did Correctly!
Modeled and textured in ZBrush!
License of use: For personal or commercial use!
Link for download below:
Abandoned Land - Only DAZ Studio 4.6 Pro
https://drive.google.com/file/d/0B4iknxaOUzncaEw3VGdHMVMza28/view?usp=sharing
182 MB
Abandoned Land - DSON Converter if used with Poser:
(you must have DSON Importer to use into Poser).
https://drive.google.com/file/d/0B4iknxaOUzncSHgwM3dvZ3ZJUjQ/view?usp=sharing
179 MB
Post edited by Gendragon3D on
«1
  • Three WishesThree Wishes Posts: 471
    Hi gedonia,
    This is a very generous thing to give away, thank you!
    I tried downloading the DAZ (non-DSON) version and opening it in DAZ Studio. When I did, I got a few error messages (see attached). It looks like the Geometries folder is missing under Runtime?
    -- dan
    jpg
    jpg
    46K
  • Gendragon3DGendragon3D Posts: 177
    you need to download another file to work!
    Copy the contents in the same directory!
    Try it and give me a feedback please!
    Thank you!
    Gendragon
  • mCasualmCasual Posts: 4,607
    edited October 2014
    hi thanks for the scene
    ( this was a post about problems with the full-scene loader but loading items 1 by 1 works fine ... i found later :)
    Post edited by mCasual on
  • edited October 2014
    Gedonia ~
    Wow. Even with light and camera presets, to boot. Thank you very, very much for this! this is extremely generous!
    Dhtapp ~
    I have it working in DS 4.6. What I had to do was install the DS file, and then downloa the Poser DSON zip. I copied the Geometries folder from the Poser zip file into this location : My Library/Runtime/Geometries
    Note : The "load all" icon does not work, even with geometries files all in the correct places. Just load everything one piece at a time from the other icons that load individual/separate pieces, and all works well in that manner.
    All works perfectly once that is done. Yes, we have to download both files to get everything needed, but once done, it works beautifully. Hope that helps!
    Post edited by Seliah (Childe of Fyre) on
    edited October 2014
    oh so like Seliah is saying, the problem is with the full-scene loader, but when loading objects 1 by 1 it works fine !
    800 x 600 - 380K
    Note: For both files work, you will need
    download and copy them all to the same source folder in "My Library!"
    The folders mentioned above and obj not found, I do not understand what happened!
    I ask a thousand excuses as it is my first attempt to create a conversion to Poser with DSON Conversion.
    I never worked with Poser and I have not installed too.
    I made this attempt because many people were complaining to me for a file to Poser.
    Archives for Daz Studio funcinaram always fine with me, even got some in
    DAZ store. http://www.daz3d.com/gendragon3d
    The textures are high resolution and have been tested on other computers.
    I apologize for my peopl limitation!
    Gedonia (Gendragon3D
    Thank you !
    It's a relief that managed to somehow load the scene!
    Bear with me, I will post new items like this and hope it does not give problems! It's hard to find tutorials in Portuguese on the subject.
    I did this conversion by force, I think it was by luck :)
    Until next time!
    Gedonia (Gendragon3D)
  • edited December 1969
    Gedonia -
    No apologies needed. Anyone who creates content, has done this sort of thing at some point. I *STILL* do it from time to time, despite my best efforts. No worries. I am just appreciative to have the item, and thankful you have offered it to us! I am already playing with it. =)
    The missing geometry files in the DS zip file is a very simple thing to fix. Only one folder needs to be added to your zip file, and it SHOULD fix this issue for DS users who do NOT download the Poser DSON zip.
    Just add your geometries files into your DS zip so that inside the zip you have this :
    My Library/Runtime/Geometries/F3D_abandoned land
    So, inside of your zip file, your file structure (for the DS version) should look like this :
    My Library/data/Freedom3Design/
    -- All *DATA* files and folders in here
    My Library/Materials/Freedom3Design/
    -- All *MATERIALS* fies and folders in here
    My Library/Presets/Cameras/Freedom3Design/
    -- All *CAMERAS* files and folders in here
    My Library/Presets/Lights/Freedom3Design/
    -- All *LIGHTS* files and folders in here
    My Library/Props/Freedom3Design/
    -- All *PROPS* files and folders in here
    My Library/Runtime/Geometries/F3D_abandoned land/
    -- All *GEOMETRY* files and folders and in here
    ((THIS is what was missing from the DS zip file that you posted))
    My Library/Runtime/Textures/Freedom3Design/
    -- All *TEXTURE* files and folders in here
    I have fixed the structure inside of your DS zip file. I will send you a link to get it, so you can see it laid out (and have a visual of what I am trying to say in words here).
    Your Poser DSON zip file looks like it is perfectly fine. This mistake is only with the DS zip, as far as I can see. (Someone, I'm sure, will correct me if I am mistaken.)
    I wish I spoke your native tongue so I could help you in your first language, but unfortunately, Portuguese is not one of my languages. I understand how hard language barriers can be, especially when needing written material.
    So, I have uploaded your zip file, and I will send you a link via your PM's here on the forum, so you can see what I am talking about inside of the zip itself.
    No, I am NOT distributing the file. I would never do that without the creator's agreement/request. I am just uploading the fixed zip file, so you can look inside of it to see the structure. I am hoping the visual will help where the language barrier makes things hard in text.
    I hope this helps.
    Seliah thank you!
    This file should never have been divided as I did!
    It was too large to download, then I forgot
    Folder geometry.
    No problem in sharing the corrected file for you.
    A decade ago that I dedicate my stuff to the public, with free materials.
    I like to share!
    Thank you for the support, helped a lot!
    Stay tuned for new freebies.
    You can find many of my freebies below:
    (Freedom3Design)
    http://www.renderosity.com/homepage.php?userid=796852
    http://www.sharecg.com/gendragon
  • MilosGulanMilosGulan Posts: 1,988
    edited October 2014
    Thank You for your wonderful freebies. I have been busy in my new fruits&vegetables; store last 2 weeks and didn't had time to download a lot or do any renders but i will have to orginize better to be able to do it. I am hoping when rain starts that i will have more free time. I wish i could do things like that :)
    Post edited by MilosGulan on
    And keep on fighting please, we need to have nice things in life, thats what i am thinking. I hope it is ok to post videos :) https://www.youtube.com/watch?v=6Csu-3sMBx0
    Very nice, thank you!
  • StratDragonStratDragon Posts: 3,278
    edited October 2014
    just fyi, looks great, still downloading but when I went to the link I clicked the file name thinking that might be the DL trigger, you may want to change the ability to do this on our end as accidents happen.
    451 x 228 - 17K
    Post edited by StratDragon on
  • Faeryl WomynFaeryl Womyn Posts: 3,741
    Is this still available somewhere, would love to get it.
  • Hy Faeryl!
    For some reason, I found the file but I contacted a friend I think he has the corrected file for Poser.
    I will return soon with an answer to it.
    Remembering that I do not work nor domino Poser, DAZ Studio only,
    I'm sorry and thank you for FeedBack.
  • GumpOtakuGumpOtaku Posts: 106
    whoa! where was your stuff been in all my journeys?
    ~GO :D
  • Hello to all!
    Requirements:
    Sorry (File deleted)
    182 MB
    179 MB
    ~GO :D
    Go for http://www.sharecg.com/pf/gendragon for others freebies.
    Daz is fine Gendragon as that is what I use.
  • I have bad news and I apologize!
    This file was damaged on my HD after a gross power outage,
    as well as many of my former jobs I had not backed up!
    Now, maybe someone has managed to download this file and corrected the errors and containing it can share with you! Example: "mCasual".
    I'm so sorry!
    I have now just as dedicated sales due to supplier
    the cost be too high.
    I hope you understand!
    I would like to end this by increasing discussion here!
    My best Regards!
    I will ask Casual and hopefully can get it that way.  Will direct to this thread to show permission to do so.  Thank you.
    edited October 2015
    on my google-drive, and for a limited time
    i will be hosting the 182 megabytes file
    F3D_abandoned land_DAZ_Studio.zip
    maybe gendragon3d could download it and upload it on his own storage site
    the URL is .....
    please tell me (in this thread) when you're done downloading the file
    i guess i'll keep it there 1 week
    https://drive.google.com/file/d/0BwB_6f4jLHoVZ0lTTVY1RjA1VG8/view?usp=sharing
    Ok I have it and thank you so much for doing this.  Perhaps Gendragon will put it on sharecg, though not sure he would be able to do it in one zip.  Have no idea if they have a size limit for uploads there.
    Great. Thanks for the file. I had it on my HD too. I am hoping those files from before can also be restored.
  • Hello everybody, my friend Jefferson of Renderosity converted the file to Poser and
    I just post it on ShareCG: http://www.sharecg.com/v/82359/browse/5/3D-Model/Abandoned-Land-for-Poser
    The file for DAZ Studio is on the way. Thank you "mCasual" m by Taze him back.
    Thank You :) Looks very nice.
  • I am happy to help!
    I would like to take writing here about a big question that I'm having. I do not know if it's the right place to ask.
    I created a huge scene for halloween theme that has lots of greenery. I used the Instances method to multiply plants and grasses, but do not know how to save or create props for each plant open normally without losing Instances. Every time I saved a prop of a particular plant with Instances,
    when I click the prop saved her, she opens herself. What should I do?
    If anyone could help me, I would be eternally grateful!
    925 x 701 - 175K
    925 x 701 - 128K
  • WitchStormWitchStorm Posts: 186
    edited October 2015
    following
    Can this still be gotten?
    Post edited by WitchStorm on
    Yes but only look up a couple posts from here.  The first post link no longer works so he put it on sharecg
