a sea of hair parameters...which one for this ?
Ok so i bought Blithe hair and i think its wonderful. And you get all the parameters you could ever want.
That is if you keep the hair black.
but i just did this close-up and i get this repetition on the left.
So, which of the 56 parameters should i push to not get this too much.
Guess it must be the same trouble with many hair assets. Or i have to do more tests.
    If you are talking about the red streaks on both sides, I doubt any morph will fix that since it is a texture issue more than anything. You are correct than most hair assets will be modeled the same way. You could try editing the texture, but chances are the same area on the texture sheet effects both sides the same since that is usually how it's UVMapped.
    maybe try a deformer or meshgrabber (in the store) to move that area of the hair a bit to make it less noticable or just use a uniform texture.
    Then again im looking at it more and more and im thinking you can get that effect with an actual curler.  Maybe i'll let let it go.
