Coral 8.1 & Male Genitalia???
DarkElf
in The Commons
So, I just purchased Coral 8.1 and was going through Coral 8.1/materials/Iray and I found two files I cannot figure out. They are materials for male gens. See the attached.
I don't get it. Could someone explain please?
Whereas Pro bundles for G8 and earlier came with genitalia corresponding to the gender of the character, 8.1 bundles come with both sets. In case you've never used them, the gens can be found under Anatomy.
Yes. I have used the gens for both male and female characters many times. But my question is, why does Coral 8.1 come with mats for male genitalia.
My first assumption was it is in case someone wanted to put G8M genitalia on Coral 8.1. So, I tested that theory and found that though you can apply the G8M genitalia to Coral 8.1 it doesn't fit correctly. So, that kind of blows that theory.
So, why does Coral 8.1 have mats for male gens?
They should fit correctly, so that means there's some fitting problem with the graft.
Because, as I said, 8.1 bundles now come with both sets of genitalia, which I might have clarified by adding "that both fit that gender". So Coral has mats for male gens because the new 8.1 male gens included in her bundle fit 8.1 females.
Make sure you're using Genesis 8.1 Male Genitalia for Female.duf that installs with Genesis 8.1 Female
Interesting.
I don't see a Genesis 8.1 Male Genitalia for Female.duf.
I have female gens but not male.
Where is it supposed to be?
The DIM seems to be installing things strangely anyway IMO.
Though I DO have a Genesis 8.1 Female directory my purchased Genesis 8.1 Female characters get installed in the Genesis 8 Female directory. In I have in my Genesis 8.1 Female directory I have only a few things. No male gens.
It should be under People/Genesis 8 Female/Anatomy
But it is a separate install and download, it is not Included with the Genesis 8/8.1 Female Essentials. Like any of the other Anatomical Elements it requires purchase of large bundle (What used to be called Pro Bundles) and if you have a previous Female Pro Bundle from before 8.1 the new Genesis 8.1 Male Genitalia for Female product should have been automatically added to your product library.
But also keep in mind that each area of the body can only have one graft replacing the specific region, so if Coral 8.1's tail happens to be a graft figure and covers the genital region, then you won't be able to use the tail and a genital (Whether male or female) at the same time. So the included genital textures would only be usable if using Coral in a human form ie. sans tail.
Hmm. I have not purchased any Genesis 8.1 pro bundles but I do have some pro bundles from Genesis 8.
But, no. I have no Genesis 8.1 Male Genitalia for Female in my People/Genesis 8 Female/Anatomy folder. There is only the Genesis 8 Female Genitalia there.
So were you just ignoring me all the times I said that the new gens came in 8.1 bundles?
Actually I don't recall buying any 8.1 pro bundles and I have all those anatomies. Download a fresh zip for the genitalia and install that ;-) [presuppos' one has at least ever purchased a pro for 8].
My Genesis 8.1 Male Genitalia for Female.duf was installed via Daz Connect in Product ID/SKU: 42089
I see an installer in DIM searching for SKU::42089
DIM should be installing it to People/Genesis 8 Female/Anatomy
So, I DID purchase the Seas the Day bundle the other day and the bens are listed in my purchases. But they were not showing up until not.
Here is how I fixed things with your help:
One of you told me to uninstall and reinstall the essentials. That fixed some issues. Files I did not see before were suddenly there. In fact, I now have icons for Genesis 8.1 female too. But the male gens for Genesis 8.1 female was still missing. So, I found the product in my purchases and uninstalled and reinstall it and they are there now.
Thank you to all of you for your assistance.
