Need I.D please
I am looking for the Column/Pillar in the promo image with the man and woman here https://www.daz3d.com/judah-weapons-collection thank you for any help.
  • GordigGordig Posts: 10,633
    Looks like a Jack Tomalin design to me, although I can't currently be any more specific.
  • JOdelJOdel Posts: 6,322
    edited August 2021
    Try Pedatron. Looks like it could be the old Andromeda set to me.
    Post edited by JOdel on
  • beachlegsbeachlegs Posts: 526
    edited August 2021
    I will go and have another look thank you JOdel :)
  • robertswwwrobertswww Posts: 799
     It looks like the column/pillar may be kitbashed (along with custom shaders), espeically since most of the other items are listed in the Additional Products Used section, such as the uneven floor with debris which is apprently from Blocks and Structures.
    If you look at the column closely, it is a fluted design and has horizontal section dividers every 1.5-feet or so. immediately below the column is a layer with an indented-corner design, and below that is 3-or-4 terraced thin horizontal surfaces, and a block with an imprinted design below that.  I believe this column design matches the one from Stonemason's The Temple Below.
    This column is then sitting on 3 base plates, of which the bottom one has an octagonal appearance. The only column I could find with an octagonal base is from Jack Tomalin's Chapter House.
    I hope that helps you if you're trying to re-create the column :)
    edited August 2021
    Thank you very much I was stuck on Stonemason's Temple part I guess because it is still new...You have been so helpful thank you very much and I am sorry for late reply my friend :)
    Glad to hear that I was able to help you in your search for the column/pillar, and I hope you were able to put together something similar.  smiley
  • richardandtracyrichardandtracy Posts: 7,306
    edited September 2021
    Looks as if you could kitbash something similar from this https://www.daz3d.com/ancient-grounds-and-40-poses-for-genesis-8-and-warrior-couple
    Post edited by richardandtracy on
