Need I.D please
beachlegs
in The Commons
I am looking for the Column/Pillar in the promo image with the man and woman here https://www.daz3d.com/judah-weapons-collection thank you for any help.
Looks like a Jack Tomalin design to me, although I can't currently be any more specific.
Try Pedatron. Looks like it could be the old Andromeda set to me.
I will go and have another look thank you JOdel :)
It looks like the column/pillar may be kitbashed (along with custom shaders), espeically since most of the other items are listed in the Additional Products Used section, such as the uneven floor with debris which is apprently from Blocks and Structures.
If you look at the column closely, it is a fluted design and has horizontal section dividers every 1.5-feet or so. immediately below the column is a layer with an indented-corner design, and below that is 3-or-4 terraced thin horizontal surfaces, and a block with an imprinted design below that. I believe this column design matches the one from Stonemason's The Temple Below.
This column is then sitting on 3 base plates, of which the bottom one has an octagonal appearance. The only column I could find with an octagonal base is from Jack Tomalin's Chapter House.
I hope that helps you if you're trying to re-create the column :)
Thank you very much I was stuck on Stonemason's Temple part I guess because it is still new...You have been so helpful thank you very much and I am sorry for late reply my friend :)
Glad to hear that I was able to help you in your search for the column/pillar, and I hope you were able to put together something similar.
