OBJ Import Bug.
lorddayradon
1.Loaded daz,
2. opened window 'figure setup'
3.add geometry (lets me select an obj)
4... this is what I get, how do I fix it so that I can adjust the import options?
Cursor has the constant circle loading in bg with the arrow, going to edges of the import window does NOT show resize arrow, and trying leads to nothing. Cancel and try again leads to same result.
Post edited by lorddayradon on
Is this happening with any obj?
You move the cursor to the bottom of that dialogue window and pull it larger.
re:
Every one I try
edit: Hitting accept anyway leads to the image below. My concern; what options if any are selected/not selected with respect to add geometry (are there any?)
What happens if you try to import it through File > Import. Can you then get to the setup.
Yes, the same window appears, in the same truncated size, but going to the edge I get the resize arrows, and it resizes successfully.
