• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Point lights shining through objects?
SnowSultanSnowSultan Posts: 3,805
August 2021 in Blender Discussion
Can someone tell me if this is normal behavior for point lights? I have a tiny one (1 watt, 5 cm) on the wick of this candle and yet it's lighting the top outer edges of the lamp that should be blocked by the upper border. Using Cycles, don't think I have anything else weird going on here. Thanks for any information.
  • PadonePadone Posts: 4,088
    August 2021 edited August 2021
    Because light bounces and crawls. That is, cycles is photoreal, not a classic raytrace engine with no global illumination. If the top of the lamp gets a separate geometry with some space for the light to pass then it will. Also there's GI.
    Post edited by Padone on August 2021
  • SnowSultanSnowSultan Posts: 3,805
    August 2021
    There is virtually no GI in that scene, everything outside of that point light is black. I don't know offhand if there is a break in that geometry at the top, but I've used this before in Studio and never had this sort of issue.
  • FishtalesFishtales Posts: 6,224
    August 2021
    Try raising the light higher on the wick. It looks like it is low enough to shine under the top border rather than the top border causing shadow. Raising the light should cause the light to shine on the border and cause it to shadow on the lip. I should also add it doesn't look wrong to me as, depending on the length of the candle inside the lantern, the light from a real lantern would look similar.
  • TheMysteryIsThePointTheMysteryIsThePoint Posts: 3,306
    August 2021
    It looks like the point light might be reflecting off of the bottom of the inside of the lamp and impinging on the top outer edges. I can't think of a case where I second-guessed cycles and I turned out to be right and cycles wrong.
    August 2021
    Sorry for the delay, I didn't have a chance to test that scene again until just now. Nothing I've tried has any effect, and while I also won't second guess Cycles, I think there might be something weird with the geometry or elsewhere. I turned roughness all the way up and moved the light around inside the lamp and that top is as bright as ever. I'm not going to worry about it now, if I needed to render this, I'd do it in two passes and just paint away the light where I don't want it. Tired of trying to get everything right in 3D programs anyway.
    Thanks for the suggestions.
  • stem_athomestem_athome Posts: 526
    August 2021
    It looks like you have glass/transparent walls on the prop. What materials are you using for that in DS and Blender?
    August 2021
    Are you sure no normals are flipped?
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
