Check out these Genesis 8 and 8.1 male and female skin overlays
2»
  • SevrinSevrin Posts: 6,314
    Thanks bunches!
  • Thank you so much and yes I use G3, actually I use all the Genesis models...lol
  • @ Spacious. These are amazing, They add new level of detail and realism that looks great. Top marks dude.
  • SpaciousSpacious Posts: 481
    Thank you!  This thread has been innactive for months, and I was thinking about taking the link down.
    I just found this because of your last post. Unfortunately I don’t have time to test it now but it looks like it works great as posted from others. Thanks for the upload! I will definitely try it when I get the chance.
  • 3dLux3dLux Posts: 1,231
    @Spacious  also found this because of your last post yes  Trying it out now and will post results when done smiley
  • CHWTCHWT Posts: 1,191
    Hey @Spacious thank you so much for your good work! They look absolutely fantastic and I would very much appreciate if you could kindly keep the download link, as I am sure that there are tons of folks out there who will be able to achieve a new level of realism with your skin overlays... maybe you would like to consider including a readme/disclaimer that your skin overlays are not merchant resource so that other people cannot steal your work?
  • James_HJames_H Posts: 1,117
    Thanks for this. Missed it first time around.
    @Spacious  Thank you so much for sharing this:  the blotchy overlay is amazing and adds an almost indefinable something to the skin.  Texted it out on characters with different skin tones, and the result, done with spectral rendering is amazing.   I did notice that in some cases I needed to tweak the lighting, but that’s no biggie.
    Here are the results, which are done in the Viewport:
    Full disclosure:  admittedly I skimmed the first post; I installed the overlays in my library blush   Which is why even though the overlay was visible in the viewport it wasn’t showing up in the render surprise  So I copied the files from the temp folder to the appropriate skin folder and manually changed the maps in the appropriate channels; something I’m used to doing for G2/3F wink
    Many thanks for sharing your work:  the girls have never looked better heart
    @3dLux Thanks for the feedback.  It's odd that it's not rendering normally for you.  The only reason I suggest not installing them in your standard DAZ library is because I recomend installing everything not directly from DAZ in a separate library.  I can't think of any real reason that it wouldn't work correctly, unless you installed it in the special protected DAZ Connect folder and tried to restart before rendering.  No non offical DAZ files can survive in that folder.
