Your guys recommended Sub-Division levels?
SchaakaSchaaka Posts: 162
A few questions:
What level of Render Sub-Division do you like to use? One that gives a nice look but not overly taxing on processing?
Should Sub-Divion level always be 0 no matter what the Render Sub Div is?
At what Sub Division level do you think starts to give diminishing returns and really not worth it?
  • margravemargrave Posts: 1,822
    Depends how close to the camera the figure is, and how much VRAM I want to use up.
    If it's a single character headshot with no environment, maybe 4 SubD. If it's a scene with three characters and they're all ten feet away, at most 1 SubD.
    You can set Viewport SubD to whatever you want. It's the only way to view HD details without doing a full render.
    No need to go above 3 unless you have an HD morph that requires higher, even then I would never go above 4.
  • JVRendererJVRenderer Posts: 664
    edited August 2021
    Full body scene : subd level 1
    Close up head shot portraits with HD subd level 3-4 (turn off denoiser, otherwise you'll lose the details)
    Post edited by JVRenderer on
