V4 to genesis 8 prop converter
Any chance there's a converter for props for Victoria 4 to genesis 8 as the only thing close RSSY v4 to genesis 8 clothing converter states it doesn't convert props?
Props are not rigged clothing so what's to convert?
File format and ability to attach it to genesis 8 female?
Well that doesn't require a converter. It requires that you rig it which can be done using the tools inside Daz Studio.
That includes necklaces and headwear?
Everything applied to your character
For necklaces and headwear, load the props in place, then one by one - use the transfer utility [from the hamburger menu on the scene tab] Figure is the donor, prop is the target ... be sure smoothing is UNchecked, for the bones select an appropriate option [NOT attachments - those are for geografts] and the program will do the work. Then select that one item and File > Save as > support assets > figure/prop to the clothing or accessory folder for the concern figure. Done. Then you can make mats etc. for it too if so desired.
