V4 to genesis 8 prop converter
Any chance there's a converter for props for Victoria 4 to genesis 8 as the only thing close RSSY v4 to genesis 8 clothing converter states it doesn't convert props?
    Props are not rigged clothing so what's to convert?
  • File format and ability to attach it to genesis 8 female?
    Well that doesn't require a converter. It requires that you rig it which can be done using the tools inside Daz Studio.
  • That includes necklaces and headwear?
  • KainjyKainjy Posts: 913
    Everything applied to your character
    For necklaces and headwear, load the props in place, then one by one - use the transfer utility [from the hamburger menu on the scene tab] Figure is the donor, prop is the target ... be sure smoothing is UNchecked, for the bones select an appropriate option [NOT attachments - those are for geografts] and the program will do the work. Then select that one item and File > Save as > support assets > figure/prop to the clothing or accessory folder for the concern figure. Done. Then you can make mats etc. for it too if so desired.
