Iray Preview won't work in a scene
When switching to Iray preview it will only display as if smooth shaded until I start moving camera cube, that's when the Iraq shows up but only as long as I hold the camera control and than it's gone again.
When switching to another saved scene Iray view works fine even though other scenes have more data in it.
I tried deleting everything accept the characters from the scene, I played with environment options, I have a new 3060 gpu rig. But nothing works.
I am worried that over time this might become an issue when working with other scenes.
What happens if you use File>New, then File>Merge to load the problem sene - does it preview correctly? If so that would suggest an issue in Render Settings, if not it sounds like one of the pieces of content.
OK, if you do that it shouldn't be any of the render or other settings as they won't 9aside from the new singleton nodes) merge with the scene. Can you load the same content into a new scene and have the preview work?
The HDRI is set in Render Settings, and in the Environment node in the Scene pane
