New tutorial using Face Transfer on Genesis 1 to use in Carrara Pro 8.5
cynthia1968cynthia1968 Posts: 36
edited July 2021 in Carrara Discussion
Hello world,
I've been experimenting a lot with Daz Studio Face Transfer and make it work in Carrara. As you probably know, Face Transfer only works on Genesis 8 models. But luckily, there is a way to get it working on Genesis 1 using Genesis 3 UVs for Genesis. Unfortunately, if you want to load the new Genesis 1 model (after using Genesis 3 UVs for Genesis), the model looks distorted.
But like I stated: there's a way to make it work in Carrara--perhaps more then one way. I created a video tutorial how to use the skin textures on a Genesis 1 model in Carrara.
<iframe width="560" height="315" src=" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Like I said, there's more than one way to skin a cat, but this is the way I get it done.
TTFN
Post edited by cynthia1968 on
    can it transfer V4 and A3 faces to 8.1?
  • HeadwaxHeadwax Posts: 10,562
    cynthia1968 said:
    Hello world,
    <iframe width="560" height="315" src="" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
    TTFN
    thanks for that tut ;)
  • mindsongmindsong Posts: 1,783
    edited July 2021
    cynthia1968 said:
    Hello world,
    TTFN
    oh this is a good one - thanks a zillion for taking the time to put this together and share it with us.
    edit to add: after watching this, would I be correct in assuming we could use any (similar) native body skin for the original genesis1 figure and then only need to follow your instructions for the new face transfer *face* map only? The neck seams might need some retouching for the best match/transition, but using your steps, the face would work, and the body would not need the extra steps since it would be native Genesis1, right? This is great. (yes I appreciate that you indicate many ways to do this, but it seems like this step would make your already clear instructions even easier!)
    --ms
    Post edited by mindsong on
    Fantastic, Cynthia!!! What a great workflow!
  • DiomedeDiomede Posts: 15,452
    Thank you very much.  Very generous to put this video together.
    +1!!! yes
  • StezzaStezza Posts: 9,193
    yes +2 yes
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,424
    appreciate the video but honestly I prefer Facegen which works in Carrara out of the box on Genesis 1&2 and does side profiles as well as front on.
