How do you get rid of bright white noise on hair in IRAY?
2»
  • bobby77bobby77 Posts: 21
    Hey Guys, I'm sure everyone has covered this issue.  I had this problem and I simply dialed down the "Glossiness."  That point may have been made several times already; didn't read every post.  Thanks for the input -- the dialogue here is what led to my solution.
  • kyoto kidkyoto kid Posts: 42,467
    ...with older 3DL hairs that are converted to Iray either by using the default Iray Uber shader or Slosh's UHT2, I found I had to increase the cutout opacity otherwise it can look like the character is suffering from hair loss due to radiation exposure.
  • Xen2kXen2k Posts: 80
    Setting the SSS value in the hair surface to 0 often solves the issue (white sparks/noise in the render) for me.
    I assume this issue was caused by one of the more recent Iray updates/adjustments so the PAs did not encounter such white sparks when the created the material files.
