Hair and headwear
What's the trick to getting hair to tuck away under headwear? It seems like my options are either having the hair clip through the headwear left and right or just have no hair attached, neither a desired option.
  • FSMCDesignsFSMCDesigns Posts: 12,855
    use a deformer, hide the mesh with the geometry editor or try one of the hat helper products in the store
  • Roman_K2Roman_K2 Posts: 1,276
    Yeah, classic hair is often made of separate parts or layers. (I'm not so sure about dForce or LAMH "hair")
    If you first select the actual hair and its geometry (as compared to the HEAD part of the figure, and the "hat") it should be fairly easy to temporarily "erase" bits of hair that are sticking out as you "touch" or swipe over them with the dragged Geometry Editor tool, in D|S.
