Released: HedgeMaker [Commercial]
13
  • TotteTotte Posts: 15,147
    Are you running 32 bit version of DAZ studio?
  • barbultbarbult Posts: 27,546
    hm_engine.dll is in IM00080936-02_HedgeMakerforDAZStudio45Win64bit.zip for me.
  • 3dLux3dLux Posts: 1,231
    Thanks for asking Totte; I only run a 64 bit version of D|S
    That explains it:  that's DIM.  Looks like I may have to bite the bullet and use it if I'm to get the product to work.
    Will try that in the morning as it's 1:05 am on my side of the world.  Am punchy from lack of sleep and my mother's death 2 days ago, so there's that.
    Thanks for the help, all; will report back on any progress or lack thereof.
    I'm so sorry to hear about your mother.
    Sorry to hear about your mother, I hope you get things sorted out.
    Thank you for that @barbult @Totte, it is gratefully appreciated.
    Downloaded  and installed IM00080936-02_HedgeMakerforDAZStudio45Win64bit.zip via DIM.  hm_engine plugin is still red sad
    I'm assuming that the hm_engine is in both the .exe file and the DIM one.  In both cases it was installed but the plugin failed on my D|S 4.12/4.15, which has been able to run other plugins successfully.
    Am open to other suggestions; I really want to use HM sad
    What version of DS are you running exactly (all 4 version sections (X.X.X.X)?
    Is it a release version of a beta version?
    Do you have Daz Studio installed in C:/Program Files, or some other custom location?
    What is an example of a plugin that is currently working for you in that version of Daz Studio (Mesh Grabber, UltraScenery Accelerator, or something like that)?
    edited July 2021
    Apologies for the late reply @barbult,  the funeral/mourning observances lasted until yesterday and it was only then I finally had time to do Daz stuff (at least for now:  my brothers and I are meeting tomorrow to talk about other matters related to Ma's passing).
    Here is the information:
    • Daz versions running-  4.12.1.118 Pro Edition 64-bit  / 4.15.0.2 Pro Edition 64-bit
    • Both are release versions; fwiw I have never run a beta version of D|S
    • D|S has been running in a custom location from the time I started using this computer; D|S is in the D drive because the C Drive is SSD and does not have as much storage
    • Info on the plugins that I currently use:
                -  Randomizable trees (works well in 4.12)
                -  Grasp Helper (works in 4.15 only)
                -  Gescon (problematic)
                -  Hedgemaker (problematic)
                -  Node positioner and grabber (works in 4.15 only)
                -  Mesh Grabber/morph editor/ rotations add on windows (works well in 4.12)
                -  Ultimate Zero (works well in 4.12)
                -  Ghost Dynamics (works well in 4.12)
                -  XTransfer (works well in 4.12)
                -  dForce Companion (works well in 4.12)
                -  Render Queue (works well in 4.12)
    Post edited by 3dLux on
    If you start DS, and look in the log.txt file (good idea to clear it first to make it less huge).
    Look for the followinglog entry
    YYYY-MM-DD hh:mm:ss.sss Loading plug-ins:
    look below for when it loads hm_engine (on my mac riht now so I don't know exactly how it look on windows, but something like
    YYYY-MM-DD hh:mm:ss.sss   hm_engine.dll
    does it yell any errors about loding it?
    It does!  This is from the log:
    2021-07-10 17:07:54.929 hm_engine.dll
    2021-07-10 17:07:54.946 D:\Program Files\DAZ 3D\DAZStudio4\plugins\hm_engine.dll failed to load. Cannot load library D:\Program Files\DAZ 3D\DAZStudio4\plugins\hm_engine.dll: The device is not ready.
    Apprarently it happens every time I start D|S 4.15 because it appeared twice before this last time stamp surprise
    Looks like you either have put a shortcut, not the actual plugin in the plugins folder, or the plugin is damaged from download/unpack.
    edited July 2021
    It turns out to have been neither:  after downloading a new .dll via the .exe and DIM and manually removing the non functional plugin time and again, I was forced to come to the conclusion that the difficulty may have been something in this computer angry  Probably the same reason why it can't run some software and some updates don't take.
    So I downloaded D|S onto the PC I use for graphic work, installed Hedge Maker...
    Et voila, it ran perfectly.
    Mystery solved; much gratitude to @Totte and @barbult for the help and advice.
    Will post the scene I've been working on when it's done caveat being the other computer can actually render it out... indecision
    edited August 2021
    I pulled out all my toys - UltraScenery, UltraScatterPro, HedgeMaker, Alienator Pro and put together this image. The fence and the bushes on the steep hillside were placed by HedgeMaker. Daffodils, bluebells, and cows were scattered with UltraScatterPro. An oak tree was replaced with an African Acacia by Alienator Pro. The basic landscape is UltraScenry, of course. It is quite the hodgepodge, but I don't care if these things don't grow together in the real world.
    2000 x 1125 - 2M
    Post edited by barbult on
    Love the work there barbult. You know how to use your tools.
  • tsroemitsroemi Posts: 3,626
    I'm sorry for being so unbelievably daft, but I just bought the Hedgemaker, and now there're two related files in DIM: Hedgemaker and Hedgemaker for DAZ Studio 4.5+ (Windows 64bit). Which one should I be installing, or both? I'm on Windows 10 64 bit, so I assume the second one - but the first one as well? Thanks very much for helping!
  • DoctorJellybeanDoctorJellybean Posts: 10,125
    Both. One contains the plugin and the other props, various tools, etc.
    DrJellyBean is correct, thanks for answering (was out with the dogs)
    Thanks very much, you both!
  • Doc AcmeDoc Acme Posts: 1,153
    This was asked early on in the thread but no follow up that I coud see:
    gitika1 said:
    How are the HedgeMaker Sets different than those created using your Alienator script?  Are they the same? Interchangeable? In different folders?
    Both want lists made but is there a means that they can use the same info so you don't have to duplicate?
    Hi, they are a little different (different implementations, specially the cover box in HedgeMaker is not in the AlienatorPro data sets). They are of course releated, but they are not interchangble.
    OK Thanks.  I'll make separate sets as needed then.
  • jmucchiellojmucchiello Posts: 2,215
    I have a question. Is there a resource anywhere with Set Builder sets premade for other artists' plant assets? I don't mean providing the assets. I mean somewhere I can get Hedgemaker - Set Builder sets for products like the various Martin J Frost plant products. Basically so I don't have to import them all, name them correctly, etc. :)
    Thanks in advance.
    Thanks in advance.
    Sorry I missed this question was when the forums were buggy, Yes, Martin J Frost has several premade sets with his Hedgerow Kits
    HedgeMaker and the HedgeMaker plugin are now updated for Studio 6, check your DIM.
  • ElorElor Posts: 4,135
    There is a typo in the name of the DS6 version of the plugin: Hedgemaker for Daz Sstudio 6 blush
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,611
    say what?
    That's an error (typo) in the name of the DIM package, not the plugin. The plugin will install with the correct name.
    I've been in contact with Daz to fix that, the typo as barbult says is in the DIM string shown in DIM.
    I didn't think it was possible to have a mistake in the name of the package but not in the name of the product (likely because the script I'm using to create package does get all the needed informations inside the .dsx files containing all the metadata), but yes, I saw the problem in DIM.
