Infernal Wings product - Why are claw nails detached?
Can anyone explain why the claw nails are detached on the "Infernal Wings" product?
Screen-shot attached.
  • MadaMada Posts: 2,065
    ok that's weird - do you have smoothing turn on very high? or is it caused by a pose?
  • FenixPhoenixFenixPhoenix Posts: 3,233
    Sometimes character morphs (shape dials) can also cause problems. So if you are applying on a dial spun character, remove the morphs one by one in case one of them is affecting the wings.
  • NorthOf45NorthOf45 Posts: 5,889
    Your claws look a little short. Use the Surface Selection tool and select one of the claws. An outline of the entire surface should show, and while hovering over a claw, the entire surface should be highlighted also, a bit dimmer. Does the surface of the claw extend into the wing, um, finger?
  • CA415CA415 Posts: 167
    Thanks everyone for your suggestions.
    Strangely enough, the next day, when I restarted DAZ Studio, the problem vanished!  It may have been due to memory corruption or a bug - I've been using the Pro Public Build exclusively.
