~Problem with Millawa 8 Head morph~ (SOLVED)
2»
  • FenixPhoenixFenixPhoenix Posts: 3,246
    avatar0319 said:
    Thank you for the answer, FenixPhoenix! But this is where it gets really weird. I just deleted, downloaded and re-installed HD Face Staples and Stitches for Genesis 8 Females with DIM - Millawa head morph still not working properly. Then I decided to download it right from my product library - got the .zip file, unpacked it and just looked at FSSF S04 without installing it. And yep, FHMMillawa8 is still there. I don't know what to think of it. One thing for sure - with HD Face Staples and Stitches installed I can't use Millawa head morph :'(
    Oh, hold on, let me take another look because we were looking at different paths (this last screenshot will be helpful). Will check this with Esid and let you know what we find.
    Is it possible that there is a botched version on some server, do you get the very same file if downloading in the US and on the other side of the globe?
    That is no corruption, but someone manually editing files and possibly inserting code to a wrong file... Except that part is referring to both products...
    Ok, this is incredibly weird. Checking the file from both DIM and Manual Install, there is indeed corruption present. Luckily, the copy I left in my hard drive (one has to love backups!) is uncorrupted. So I'll be issuing an update as soon as possible. But first, @avatar0319, could you test this file for me just to confirm that the issue is gone? I'm attaching the correction. Simply replace this with the file in your system.
    zip
    zip
    HFSSforG8F-Update.zip
    74K
    Not sure, but something must have indeed happened at some point during the process to submit the file. The thing is, the morph wasn't even kicking in, so it would've been apparent during testing that it wasn't working. But the whole process happened so long ago, it would be anyone's guess what happened or how. Hopefully the fix works, though.
  • avatar0319avatar0319 Posts: 19
    edited July 2021
    YEP! Can confirm it - the issue is gone now! Millawa head morph slider is working as it should be. Thank you for such a quick response, FenixPhoenix :)
    Post edited by avatar0319 on
    edited July 2021
    Not a problem, thank you for confirming so quickly. I'll issue an update right away. Glad we managed to fix this so quickly and I apologize for the inconvenience the corruption caused!
    PS: I've sent you a Private Message. :)
    Post edited by FenixPhoenix on
