Is it possible to rearrange my script menu?
JoltrastJoltrast Posts: 208
edited June 2021 in The Commons
I'd like to tidy up my quick access script menu. Is there a way to do that please? Thanks!
Post edited by Joltrast on
  • NorthOf45NorthOf45 Posts: 5,707
    edited June 2021
    Absolutely. Menu -> (ed.) Window -> Workspace -> Customize (or just F3). On the right panel, select the Menus tab. Expand the Main Menu Bar entry to get to the Scripts entry. Expand that one, and so on, to show the items. Click and drag the entries into the order you want. You can add sub-menus to group similar functions together. The GUI might be hard to see, mine highlights source and target areas as I drag over them (didn't use to do that), but there is a line the follows your cursor (mine is white on a bright yellow highlight, but it is there).
    ETA: corrected menu path...
    Post edited by NorthOf45 on
  • JoltrastJoltrast Posts: 208
    Yep, found it, thanks. It's a bit hidden and not 100% intuative, but eventually I got it working. Thanks!
