Daz Studio Pro BETA - version 4.15.0.30! (*UPDATED*)
1161719212226
  • JoltrastJoltrast Posts: 208
    jbowler said:
    Richard Haseltine said:
    fatimaroncally said:
    I closed the background thread at least 50 times without any drawbacks or damages. By the way I do use the scrit to open several instances. This script also only works when the background thread has been closed.
    Use the script to create one or more additional DS instance shortcuts, so they are ready for use.
    Or launch DAZStudio and never use it; instead just run the script (attach it to the menus via a custom action) each time a new DAZStudio is required.  This has the additional advantage that UI settings can be changed in the "launcher" DAZStudio and will stick (after a relaunch of that DAZStudio).  Startup of the instances may be faster too, it certainly shouldn't be any slower.
    Can this be used to retrieve a file that would otherwise be lost when DAZ crashes? (I'm assuming not).
  • jbowlerjbowler Posts: 867
    edited June 2021
    No; it only allows you to use more than one instance of DAZ Studio at once *and* to change preferences in the (unused) launcher instance so that they stick.  Other ways of having multiple instances don't allow direct changing of the preferences because any changes get lost when the instance is closed and there is no "master" instance running (though you can just run DAZ Studio directly to change preferences).
    Recovering from a crash and retaining date is certainly possible; Microsoft Office started doing that around 2000, however DAZ Studio doesn't even do the basic think that Office did before the save-on-crash stuff.  Office would autosave to a temporary file on a very regular basis so that the actual data loss after a crash was only a couple of minutes work, if that.  Lots of programs do that.
    Post edited by jbowler on
  • akmerlowakmerlow Posts: 1,124
    Hi, can i install a beta AND have a totally separate library folder/content for it?
  • DoctorJellybeanDoctorJellybean Posts: 10,121
    Any particular reason for wanting to do that?
  • barbultbarbult Posts: 27,531
    Sure, just map different content folders with the Content Directory Manager inside Daz Studio. Installing the content to separate content folders might be messy, though, unless you did manual install.
    edited June 2021
    Thanks for replies.
    Two of them.
    1) I'm still on DAZ 4.8 on my 2015 era pc (i5-6500, gtx 960 vram 4 gb, 16 gb ram) and i'm not sure if it uses same library/CMS stuff
    2) I'm planning to get an additional hdd, so would like to have new library there for Beta D|S, while keeping existing installations where they are.
    I always manual install when i can. Old habit since Poser days (same with Bryce laugh).
    Post edited by akmerlow on
    akmerlow said:
    Thanks for replies.
    Two of them.
    Use DIM to install, and add the new content path: click the gear icon top right, select Advanced Settings. Select the Installation tab and click the plus button bottom left to add the new content path.
    You can then use the original content path for the current installation, and the new path for the Beta content.
  • Richard HaseltineRichard Haseltine Posts: 111,470
    If you are still on 4.8 I think you might still be using the old Valentina database, although if you hadn't had a lot of older versions you might have started with PostgreSQL. Certainly the database (I can't recall if it was 4.8 or 4.9 that finally dropped Valentina support). Check task manager while DS is running, if you enable the Show Details then the PostgreSQL processes would appear below the list of visible applications, along with all the other background processes.
    edited June 2021
    Will follow, thank you.
    Also installed new DIM just now (wow, 64-bit!)  wink
    Oh, nice!
    It, indeed, says "postgreSQL server" in details on my 4.8
    edited June 2021
    I'm actually trying to use this fancy beta edition.
    Not a coder, don't get mad at me. I don't see what a list of plugins has to do with why it crashed. Wasn't using every plugin, was simply dialing in/out some newly made morphs on G8.1.
    You can have this for whatever it means:
    DAZStudio.exe caused ACCESS_VIOLATION in module "C:\Program Files\DAZ 3D\DAZStudio4 Public Build\QtCore4.dll" at 0033:000000005818E84B, QCoreApplicationPrivate::sendThroughApplicationEventFilters()+43 byte(s)
    RAX=000000000629E660  RBX=000000000000003D
    RCX=000000000658E900  RDX=00000000971CE860
    RSI=000000000658E900  RDI=00000000013FA940
    FLG=00010206          RBP=00000000971CE860
    It was a relatively long set of morphs I was setting up, of course, near the end just before the save you know, of course ... mutter, mutter, mutter ...
    It will "not" keep the Scripts nor the Favorites listed on the top bar.
    Saving layout does not keep these either.
    Post edited by Catherine3678ab on
  • drew.hopkins1drew.hopkins1 Posts: 15
    edited August 2021
    Edit - UPDATE: DISREGARD... I had an old driver installed for another program and forgot to swap to the latest one, which worked just fine when I did update it.
    New user here. I only downloaded/installed DAZ 4 days ago and I am running WIN10 with a 3060 GPU. I can't get DAZ to use my GPU for rendering. The log below is when I have CPU fall back disabled. If I have it enabled, then it will give a CUDA Error Message 700.and use my CPU. I did my first renders tonight, using the free Studio 19 environment and one 8.1 model. It took an hour and 41 minutes for the first render and I felt that was wrong, so I started looking for solutions. I downloaded GPU-Z and that too showed my GPU wasn't being used. I've seen this error mentioned before, but last time I saw the solution was to turn off Optix (or something similar to that); however, that's not in this version. i would apprecaite any assistance you can give. Thank you.
    Post edited by drew.hopkins1 on
  • Is this the version that's suppossed to work on Mac Big Sur?  Regardless, I can't install it because I installed Daz Central and it crashes on me every time I try and use it, so I uninstalled it.  And when I try and use DIM, it says it needs to be updated, but I can't find where to update it.  Any suggestions?
  • LeanaLeana Posts: 13,520
    No. Only DS5 will work with Big Sur.
  • my mouse cursor does the diappering act too. thought it was me falling asleep at the wheel.
  • Where do I report bugs with this beta version? I finally managed to get it working on Big Sur, but it crashes a lot and now it's refusing to save a file (I tried Save As, which worked once and not since). It tells me to see the log for details; when I try to do that, absolutely nothing happens (I mean I click on 'view log' and... nothing happens. As if I hadn't clicked on it).
    It's nice to have *some* kind of DS back but... um, saving a file is something I need to be able to do!
    So far as I know DAZ Productions doesn't have a public facing bug reporting system.  Instead you click on "HELP" (above), click on "Find Answers" (in the middle of the page), this opens a new window, then click on "Submit a Request" at the top rightish.
    Good luck with the new beta.  Not sure I'd describe a Beta release as "work[ing]"...
  • TedBuskTedBusk Posts: 10
    Process:               DAZStudio [2285]
    Path:                  /Applications/DAZ 3D/*/DAZStudio.app/Contents/MacOS/DAZStudio
    Identifier:            com.DAZ.DAZStudio
    Version:               4.15.0.2 (4.15.0.2)
    Code Type:             X86-64 (Native)
    Parent Process:        ??? [1]
    Responsible:           DAZStudio [2285]
    User ID:               501
    Date/Time:             2021-08-18 10:15:17.433 +0200
    OS Version:            macOS 11.3.1 (20E241)
    Report Version:        12
    Bridge OS Version:     5.3 (18P4556)
    Anonymous UUID:        99020DE6-B52E-7348-CA0B-F6492909ABB4
    Time Awake Since Boot: 4100 seconds
    System Integrity Protection: enabled
    Crashed Thread:        0
    Exception Type:        EXC_CRASH (SIGABRT)
    Exception Codes:       0x0000000000000000, 0x0000000000000000
    Exception Note:        EXC_CORPSE_NOTIFY
    Termination Reason:    DYLD, [0x1] Library missing
    Application Specific Information:
    dyld: launch, loading dependent libraries
    Dyld Error Message:
      dyld: No shared cache present
    Library not loaded: /usr/lib/libstdc++.6.dylib
      Referenced from: /Applications/DAZ 3D/*/DAZStudio.app/Contents/MacOS/DAZStudio
      Reason: image not found
    Binary Images:
           0x100000000 -        0x100002fff +com.DAZ.DAZStudio (4.15.0.2 - 4.15.0.2) <D215B209-B83E-EEB7-1B52-A97641EDF090> /Applications/DAZ 3D/*/DAZStudio.app/Contents/MacOS/DAZStudio
           0x100006000 -        0x1028fbfff +libdzcore.dylib (1) <957FA7BF-0584-B3F8-E8BF-B274B359158F> /Applications/DAZ 3D/*/libdzcore.dylib
           0x102fc7000 -        0x103277fff +QtCore (4.8.7) <4CA3C606-A089-F187-979B-7B48C41EC059> /Applications/DAZ 3D/*/QtCore.framework/Versions/4/QtCore
           0x10330b000 -        0x103cd5fff +QtGui (4.8.7) <83428699-BE40-1D52-E6DE-D119AFD0A1B1> /Applications/DAZ 3D/*/QtGui.framework/Versions/4/QtGui
        0x7fff64dde000 -     0x7fff64e79fff  dyld (851.27) <7EAA668B-F906-3BAA-A980-139BBE6E8766> /usr/lib/dyld
    Model: MacPro7,1, BootROM 1554.100.64.0.0 (iBridge: 18.16.14556.0.0,0), 12 processors, 12-Core Intel Xeon W, 3,3 GHz, 96 GB, SMC
    Graphics: kHW_AMDRadeonPro580XwithAMDItem, AMD Radeon Pro 580X, spdisplays_pcie_device, 8 GB
    Memory Module: Slot 1 (Channel F / DIMM 1), 16 GB, DDR4 R-DIMM, 2933 MHz, Micron, 18ASF2G72PZ-2G9E6
    Memory Module: Slot 3 (Channel E / DIMM 1), 16 GB, DDR4 R-DIMM, 2933 MHz, Micron, 18ASF2G72PZ-2G9E6
    Memory Module: Slot 5 (Channel D / DIMM 1), 16 GB, DDR4 R-DIMM, 2933 MHz, Micron, 18ASF2G72PZ-2G9E6
    Memory Module: Slot 8 (Channel A / DIMM 1), 16 GB, DDR4 R-DIMM, 2933 MHz, Micron, 18ASF2G72PZ-2G9E6
    Memory Module: Slot 10 (Channel B / DIMM 1), 16 GB, DDR4 R-DIMM, 2933 MHz, Micron, 18ASF2G72PZ-2G9E6
    Memory Module: Slot 12 (Channel C / DIMM 1), 16 GB, DDR4 R-DIMM, 2933 MHz, Micron, 18ASF2G72PZ-2G9E6
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x7BF), wl0: Feb 16 2021 03:05:58 version 9.30.444.10.32.5.67 FWID 01-3d719d60
    Bluetooth: Version 8.0.4d18, 3 services, 27 devices, 1 incoming serial ports
    Network Service: Ethernet 1, Ethernet, en0
    PCI Card: AMD Radeon Pro 580X, sppci_displaycontroller, Slot-1@7,0,0
    PCI Card: pci1002,aaf0, sppci_audiodevice, Slot-1@7,0,1
    PCI Card: pci1b21,2142, sppci_usbxhci, Slot-7@13,0,0
    PCI Card: pci1b21,2142, sppci_usbxhci, Slot-7@14,0,0
    PCI Card: XHC4, sppci_usbxhci, Thunderbolt@142,0,0
    PCI Card: pci8086,15eb, sppci_thunderbolt, Thunderbolt@143,0,0
    Serial ATA Device: TOSHIBA MD06ACA800V, 8 TB
    Serial ATA Device: TOSHIBA HDWD120, 2 TB
    USB Device: USB 3.1 Bus
    USB Device: USB2.0 Hub
    USB Device: USB Optical Mouse
    USB Device: Scarlett 18i20 USB
    USB Device: USB 3.0 Bus
    USB Device: iLok
    USB Device: USB-Serial (0001)
    USB Device: eLicenser
    USB Device: USB 2.0 BILLBOARD
    USB Device: Magic Keyboard with Numeric Keypad
    USB Device: Apple T2 Bus
    USB Device: Headset
    USB Device: Apple T2 Controller
    Thunderbolt Bus: Mac Pro, Apple Inc., 63.3
    That is not the BigSur compatible beta version.
    Correct, the compatible version is 4.15.0.25
    4.15.0.2 is the latest I can install with my DazCentral.
    Is there a direct download for 4.15.0.25 ?
    Have you 'bought' the beta version from DAZ store?
    I have been told Central cannot install beta versions, for that you need DIM.
    That is correct
    But where do I find Beta 4.15.0.25 ?
  • wsterdanwsterdan Posts: 3,589
    edited August 2021
    Oops, sorry, answering a different question, please disregard...
    Post edited by wsterdan on
    edited August 2021
    https://www.daz3d.com/daz-studio-beta
    Post edited by PerttiA on
    Plus DIM is required and the above page doesn't seem to have a link to it:
    https://www.daz3d.com/install-manager-info
    I assume that will download the MacOS version on a Mac.  After an installation with DAZCentral DIM should just find the existing content, then the instructions on the beta page (together with the "purchase" of the beta) should be enough to install it.
    Thanks guys. My DIM is the latest update, but discovered I had turned off my Release Channel Tagswink
  • SergoyelesSergoyeles Posts: 11
    edited August 2021
    Since the 4.15.0.25 update I can't load some of my scenes, Daz takes infinite time to load when it tries to load some assets / files like "PHMEyelashescurl.dsf" and "bs_tearProjectionShape.dsf" (wich are related with Genesis 8 and Genesis 8.1 I think) and simply Daz doesn't respond when it tries to load these parts of the scene and it gets stuck (same if I try to load the items wich contains that assets in the scene like Gen8 Eyelashes or Gen8.1 Tears)
    I have no problems with the same scene in the previous 4.15.14 and public release version.
    (Sorry my bad english btw)
    Post edited by Sergoyeles on
  • nicsttnicstt Posts: 11,715
    Then restore to the version you like
