New beta available: PBR, microfacets, Disney, Fresnel and tutti quanti
15678911»
    and the Materialize would make the extra maps it would need.
    the free pbr site gave me more shaders to get started.  i d/l the blender versions.
    starting all over again.  just thinkin i shoulda test rendered without the albedo maps on.  and spin it to test for twinklies.  and need practice putting height maps in the displacement channel.
    should i be using the luxus for carrara renderer?
  • DartanbeckDartanbeck Posts: 21,249
    Luxus is entirely different. Different shaders, different lighting... Luxus for Carrara at Carrara Cafe
    so between pbr and phong tesselation ?
    all poser and daz studio displacement maps should go into phong tesselation?
    and pbr height maps go into carrara displacement channel?
    what should go into the clearcoat channels?  there are 2
    Thanks.  today is pbr power day
    stumbled on a weird one
    working on the abraham hair  https://www.daz3d.com/abraham-hair-and-mustache-for-genesis-8-males
    when i drop the iray shader into the pbr drop box, it looks like its not taking the maps.  the shader tiles are empty ?
    could it be cause of the naming convention of the files?
    1056 x 587 - 107K
    1154 x 583 - 115K
    685 x 572 - 95K
    629 x 505 - 70K
  • Philemo_CarraraPhilemo_Carrara Posts: 1,175
    Difficult to say.
    Could you PM me one of those shaders?
    edited May 2021
    Thanks.  i don't see a way to attach a file in a pm.
    i tried pm ing code snippet, but it sent only a blank message.  sorry.
    txt
    txt
    iray.txt
    1M
    Post edited by Mistara on
    edited May 2021
    oh dear.  cant use either import option with this set
    the albedo and the diff map look the same to me.
    the AO looks like a plain white jpg to me. ?
    so confuzed
    673 x 383 - 75K
    rememver the rdna node cult and bagginsbill?
    he figured out how to use a poser math node, to make a color gradient color  down  a dynamic hair strand. from root to tip it changed colors with the color gradient.  was kewl.  so many mysteries in the carrara shader room.  math functions.
    i'm making guesses on the displacement  https://www.daz3d.com/medieval-brick-collection-pbr-textures
    i think it looks close to the promos.
    there no metallic map.
    1280 x 720 - 532K
    One possible (manual) solution would be as follows:
    1. Load in something that you know Does work with the PBR importer
    2. Use the PBR Importer to load the Iray presets
    3. Load in the Hair that Doesn't work
    4. Use the PBR Importer on it again, even knowing it doesn't work
    Now look at the shaders in the working object and see which maps go where, and manually load the correct maps into the correct portions of the Hair that isn't accepting the presets.
    I do these sorts of manual load procedures whenever I really like how a preset works, but there are no presets for what I'm trying to set up.
    An example being Iray shaders for Genesis 1. I really liked how one of the new Genesis 3 or 8 (?) characters looked out of the box, so I loaded that character in with the Genesis 1 I wanted to change.
    Then I just
    1. Select the Genesis 1 figure
    2. Apply the Daz Iray Uber shader to it
    3. Copy a skin surfaces from the newer Iray character
    4. Paste that surface material to the corresponding zones of Genesis 1
    5. Change the maps to the ones I need for my Genesis 1 figure
    6. Paste again to other zones that use the same material settings
    7. Change those maps for the correct zone
    8. Etc.,
    9. Etc.,
    many of those iray presets, just change settings.  like translucency,  some change tilings.  no actual maps in the preset.
    still pbr-ing
    trying my luck with pbr ground cover shader.  is just albedo, normal, and displacement.
    trying it with displacement subdivision enabled.
    1280 x 720 - 1M
    1280 x 720 - 781K
    some of the character iray presets are trying to apply to the figure and eyelashes at the same time.  hierachal mats.
    soon as i saw the roughness map, knew this was a job for pbr
    the import from duf didn't work for Rosita, so i used the import from directory.
    the import from Duf isn't bringing in the maps for Leony.
    i tried resaing the materials from DS.  there's so many options.  havent hit on the combination of success.
    maybe i broke the plugin?  the import from directory still works.
    i don't know what to do? the import from duf was such a beautiful thing.
    343 x 482 - 31K
    858 x 585 - 82K
    does it translate iray opacity?
    sotty if i'm being a pest. blush i'm just really enthused for this plugin,
    i been posting my pbr/hdr nudes on rossy gallery, not really exciting comments.  mebbe its the lack of eyelashes
    It does, at least on the shaders I've tested. Difficult to say without inspecting the DUF file.
    experimenting with the clearcast slots.  tried albedo maps. ao maps.
    the only tutorial i could find for moist skin was an arnold6 utube
    edited June 2021
    tried 2 shader sets with the drag and drop method
    on steep sale discount smiley  https://www.daz3d.com/elaborate-metals-iray-shaders
    doesn't load in the texture maps.
    do you think these liquid iray shaders would work?  even if to setup manually.
    https://www.daz3d.com/liquid-3-iray-shaders--mixed-cocktails
    for 3 bux hurts to pass up.
    also found the fenric tool to adjust bump amplitude doesn't work on the pbr shader.  guessing it can't find the channel.
    is there a way to make the native metal shaders, jpg-less, into pbr?
    mebbe use the noise or cel patterns ?
    i'm up to somewhere round 90 shaders i haz to add the disp map to, dont know if i have the fortitude.
    i know i pushing it, blush,
    if there another beta planned, a slot for disp channel would be brilliant.
    and an option to set bump aplitude to like 10 % would be awesomes.
    and the iray opacity map to alpha channel heart
    my work on the 41food pbrs looks terrible. crying
    the anicient bricks looking not so bad.
    anything new in pbrville?
    i still trying tomake the ground pbrs i bought look 'not so tiled' lol
