off topic thread
19091939596100
    oh mann,  sometimes i buy an outfit with a specific character in mind,
    when the time comes, no idea what it was called.
    memory farts
    sometimes dragging a shader over a plane, plane surface refuses to turn red
    its spiting me, isn't it
    sometimes trying to load a duf shader, adds a line to the instances, parenting it instead of applying it, more spite?  cool
    Ohh  when using the old poser hand poses, carrara is kind enough to ask left or right
    theres no drop to floor command?
    it was in poser?
    when to use blend, when to use multiply?
    i mixed the bump map with the albedo using multiply.  but now i want to add the bump map again but invert the colors.
    i can't use a curve filter over the whole body?  would have to do it for each domain?
    what does that global shader do?  it doesnt flow down to each domains
    edited June 2021
    are they letting people into australia yet?
    if they give me disability, i wanna go where the ale is chill, if not, i retire in 2 years.  need ale more than ever.
    tired of them telling me not to drink, when i gots more aches and pains than ever. bone gnomes
    where the roos and wombies roam free. and emus stop by for a visit.
    Post edited by Mistara on
    i dont understand how i lose the production frame. what am i doing wrong?
    viewing proeuction frame and showing production frame are 2 separate steps. easy enough to remember.
  • mschackmschack Posts: 337
    edited June 2021
    I have found that if you set the production frame almost to the edge of your screen in the assembly room and then later resize the render, sometimes the frame will go off the screen.
    Post edited by mschack on
    i'm uduslly near the edges.  i should keep it smaller see if that helps.
    thanks
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,517
    under the magnifying glass icon set it to default zoom and whatever to fix it
    nothing i do in the shader room changes the volumetric cloud.
    so i guess there no such thing as a volumetric shader
  • SileneUKSileneUK Posts: 1,977
    edited June 2021
    Thanks all for recommending Genteal tears!!
    It has a similar ingredient to Theoloz, but is different and more gel than water drops, but NOT an icky ointment so I can use it during the day and get on with things.  I got it off eBay UK and have been using it for a few days.  It works well!  I would expect that if it was not high pollen season it would work even better.
    THANK YOU  THANK YOU  THANK YOU!
    heartkiss  Silene
    Post edited by SileneUK on
    scene inventory progress
    all my nursoda into carrara, most of 3du, a couple more to do
    brazoers. spell books, rocket ships, thrones, clock towers, 1 castle, cryo pods
    1 set of bricks pbr, half a set of food pbr, Lara, Rosita, and Rynne
    1 shabby kitchenette set
    i burnt out a lil on the toons,
    Malik needs a square dancing stage for his fiddlestixing.  dosey doe
    a kiddie pool.
    getttin started on the fleet ops
    crossing fingers theres no issues with the french quarter
    a kiddie pool.
    You forgot the kitchen sink!! laughheartdevil  Silene
  • DiomedeDiomede Posts: 15,401
    SileneUK - so glad you found something that is helping.  Cheers to Genteal tears!
    That happens to me sometimes.  Aaargh.
    edited June 2021
    i did forget the kitchen sink.  dohhh
    oh wait, 3dage made us a carrara kitchen
    Stezza made the official carrara can opener. laugh
  • DartanbeckDartanbeck Posts: 21,988
    heartkiss  Silene
    Yaaay! Nice, juicy eyes again!!! :)
    Try opening a plant shader and see if you can figure out how they do that. It's a single shader that allows separate shaders for all domain in one stack.
    As for the other thing, try using "Add".
    Add will use the 'added' map to brighten any pixels on the 'added to' map. So anything that is not black on the 'added' map will raise the L value (and others) of the other map.
    If you use the curve filter, you can simply Ctrl+Drag to copy the curve to the other shaders, then just replace the map that's being filtered. Well, that goes for anything - not just the curve filter.
    The volumetric cloud model room is a volumetric shader. It's just not used in the texture room. Same with PrimiVol, which takes thing much further. Brilliant plugin!
    I believe that the Fire Primitive is also a volumetric shader. I could be wrong cheeky
    edited June 2021
    yes Yep. Works every time!
    Post edited by Dartanbeck on
    all these years been glossing over the insert formula.  can imagine what kind of magics it can do
    you can always make things out of volumetric clouds by surface replication and making the object they are replicated on invisible, there can be several clouds which can have different colours.
    clouds can also have a box, cylinder or sphere shape so can fill most containers
    http://gianp.free.fr/carrara/indexcarrara.html
  • StezzaStezza Posts: 8,882
    edited June 2021
    Sydney is in lockdown....
    hope it don't spread down south to my area... sad
    update:
    Sydney, Blue Mtns, Central Coast & Wollongong under 2 week lockdown from 6pm tonight ( just under 3 hours away )
    dunno if @Headwax comes under that... I'm a bit further south so not included. crying
    Post edited by Stezza on
  • Bunyip02Bunyip02 Posts: 9,290
    update:
    Stay Safe frown
  • HeadwaxHeadwax Posts: 10,458
    update:
    Stay Safe frown
    thanks and the same to both of you, i am in newie and the wind is blowing north east !
    Time to see dan murphys!
    Wish gladys was more timely
    heartkiss
    Great news !
    why is it lockdown?
    is a storm ontheway?
    prayers with yous
    out of curiosity, was reading the blender forum and their headaches with content.
    to be fair, blender isn't a daz software. and the bridge is freeware.
