conforming figure to another figure's shape.
KRISHANKOKRISHANKO Posts: 97
edited June 2021 in The Commons
so im trying to do several nature pics for a school project and i want to make a snake eating an ostrich egg while using typical descriptions of how it can unhinge its jaw and yada yada yada.
i want to make a pic where the egg is, like, in the middle of the snake, and that the snake's belly shapes around the egg. i tried manually posing each segment but it looks hideous.
is there a way?
(i only used the chzor egg as an example since it was the first result with "egg" in my library
Post edited by KRISHANKO on
  • GordigGordig Posts: 10,749
    You could probably make a dFormer (Create -> New dFormer), maybe scale it a little on one axis so it's ovular, then move that down the snake's spine as needed.
  • KRISHANKOKRISHANKO Posts: 97
    edited June 2021
    i tried that but still looks bad. not as bad as manually adjusting the morphs, but still EUGH.
    ive have happened to see rather... questionable stuff in deviantart with snake and, lets say, women. but what caught my attention was how the snake was perfectly formed around them.
    i tried asking one of the creators but he never answered.
  • PixelSploitingPixelSploiting Posts: 898
    edited June 2021
     They're probably doing this by combining new morphs with smoothing modifiers. If I wanted to make a monster eating something I'd export the snake shape to Blender along with the egg, shrinkwrap the snake model around the meal, correct the poke-through and then export the .obj of the adjusted snake shape with the morph loader in daz. SimTenero Shape Reprojector might be your best bet for doing this without Blender because it's something similiar but automated for using only Daz.
    Post edited by PixelSploiting on
  • blazblaz Posts: 261
    How dense is the snakes mesh? You won't get good results if it's really low. You can try adding a smoothing modifier to the snake and set the egg as collision item. Might help. Or you could try to dforce part of the snake. Increase the size of the egg on a timeline.
    Lasciare said:
    This looks really good! Never saw it before.
    how do i add a smoothing modifier?
  • FSMCDesignsFSMCDesigns Posts: 12,855
    select the figure, then edit - figure - geometry - add smoothing modifier
    ill try that and post back, thanks
    edited June 2021
    that worked halfway, how do i set the egg as a collision item?
    Select the item after you added smoothing. Then in the parameters tab, looking for the mesh smoothing section and there will be a drop down for collision item which would be the egg
    edited June 2021
    alright thanks. alternatively im trying the simtenero script and its been 2 hours and has only started pass 1.... of who knows how many.
    one of the questionable things i saw on deviantart was an animation where the snake would deform realistically as the woman... well you know.
    and i cant even make an egg...
    edited June 2021
     It really depends on two things - how dense/uniform is the mesh they were using for the snake AND how much of the snake shape was modified. It's not very hard to create custom morphs for figures. If they're doing animations they very likely know they way around 3d. Exporting meshes, modifying them to desired shape, using those as morph sources etc. Very few things can be made with DAZ alone.
    well guy did say that was done entirely in daz...
    i give up, im gonna use photoshop. thankls anyway guys!
  • pjwhoopie4801218pjwhoopie4801218 Posts: 795
    edited June 2021
    Ok... I just thought of something.
    I needed to have a figure wear a hat.  So all the thair that was "under" the hat, I needed to have "go away" so it wouldn't poke thorugh.
    I did a search an dfound that mcasual has a script called "hats are the fashion of the day" (Link to thread talking about it here on Daz)
    To make it work, it needs another mcasual script called mcjCollider plugin
    What I thought was happening with those scripts was that they (the script) was "erasing" the part of the hair that I didn't want.... but after using it (and it worked for hats/hair) I discovered that what it was doing was sucking the hair down close to the skull.
    I am not sure you could use it, but you might be smart enough about it to figure out how to make it do what you want....  because that is essentially what you would be doing, sucking the body of the snake down around the object.
    Cheers!
    Post edited by pjwhoopie4801218 on
  • mCasualmCasual Posts: 4,607
    i dont think the hat script could work it shrinks the hair above a plane
    https://sites.google.com/site/mcasualsdazscripts9/mcjhatsarethefashionoftheday
    but i have a script named ... what was it ? .... mcjsuperlathe
    https://sites.google.com/site/mcasualsdazscripts2/mcjsuperlathe
    it lets you draw the shrinkage/stretching
    there's another one that's simpler to use but the deformations are selected among a limited number of shapes, but for an egg shape it may work
    https://sites.google.com/site/mcasualsdazscripts4/mcjaddradialmorph
