dForce Petite Style Dolly Dress for Genesis 8 Females on adult figure?
Richard Haseltine
Has anyone tried dForce Petite Style Dolly Dress for Genesis 8 Females on a base Genesis 8(.1) Female, or an adult character shape? If so how well did it work? Thank you for any feedback.
I'm hoping to have a first look at it tomorrow (European time), will try with an adult character then if no one beats me to it!
Thank you.
I too wondered how it would look on an adult figure.
mmmm not so good don't think, breasts can cause pop out. Was thinking do I want to keep or not but it'd be useful for some creepy doll characters for me I think still, was hoping the hat was part of the outfit too but no you don't get that. This is Latonya, Babina, Bugga Boo, Dolly and Karryssa
Is this before or after you dforced it?
I tried it on Albany and it worked quite well with the frill collar on (pic 1); however, if you make that invisible there's a small amount of poke-through in the nipple area (pic 2, had to put her arm across it b/c TOS). That's before and after dforcing, so it doesn't really change. There's no chest adaption morph either as far as I could see. Still looks rather nice I think.
Thank you, not quite how I was expecting it to look.
Yes, if you have the niples on it's usually a good idea to turn them off - unless the dress has enough geometry of its own there it probably won't be able to accomodate them, and in most cases clothing would flatten them or push them in anyway.
No, it's a bit more than just the nipples, but not that much really. A pretty easy fix. I'll also play around with the dforce settings / weight map I guess, the folds really are a bit too stiff. But here, I just wanted to show the dress out of the box.
no dforce if I did be a massive explosion with all of them in it always is for me oh and breasts nipples issue in mine didn't have nipples so they were flat Babina wasn't too bad there but Laytona with larger breasts had poke through had to use smoother and collision to fix. Personally for me I think not so good for adults but need stuff for creepy dolls and some seen have that stiff dress look
thanks wish listed that now,
