shaving brush anywhere?
JUJUJUJU Posts: 1,133
I am looking for a shaving brush.
Is there anywhere one? Maybe free?
  • CybersoxCybersox Posts: 10,001
    edited September 2014
    There are two different ones in Greenpots Barber Shop over at Rendo. Unfortunately they use poser materials on the bristles so you have to add your own if you're using DS. The uber-quickies below use a Fabricator bamboo shader (left) and a blond texture from Goldtassel's Chic hair on the right. Using a grass shade would probably give even better results and make the ends of the bristles more naturally ragged.
    1000 x 1000 - 171K
    Post edited by Cybersox on
  • JUJUJUJU Posts: 1,133
    Thank you very much! Good idea that with the gras shader. I will have a look on the pottery I have and which could make a shaving brush with some gras on it ;)
  • NovicaNovica Posts: 23,925
    http://www.daz3d.com/everyday-cosmetics
    Also has a bristle brush in it, you could just embed it in one of the ceramic pots. :)
    That is also a good idea!
    Thank you.
    I tried a brush of http://www.daz3d.com/scandalous-makeup-set
    and a pottery of http://www.daz3d.com/spanish-rose-macetas-de-flores
    (cause I own this to sets ;) )
    an get this ...not bad, I think that will do the job ;)
    393 x 454 - 49K
    I like that! Nice job. Will certainly work.
