Blender 2.92 - Can't find DaztoBlender on Addons
wintoons
Hi,
Just installed 2.92, anyone had trouble installing the DaztoBlender addon on Blender?
Or is it Blender Bridge not updated yet?
I got trouble too. The new version is not working for me
. The add on is not in the add on folder. My location is: C:\Users\User\AppData\Roaming\Blender Foundation\Blender\2.92\scripts\addons\DTB\ (turn, see hidden folders on.)
MeToo - but it could be you need to re-install the bridge - in the right order..
I had previously uninstalled both DAZ and Blender.
I did a fresh install of DAZ this week - including DTB. Today, I did a fresh install of Blender 2.92 - but could not find the DTB addon in Blender Preferences. I un-installed DTB, re-downloaded it, and reinstalled ( a matter of mere moments). Restarted Blender 2.92 which could then see the DTB addon in Preferences - and it now appears in the toolshelf - after being switched on in Preferences.
It looks like: without Blender installed, InstallManager puts/parks the DTB in "C:\Users\User\AppData\Roaming\Blender Foundation\Blender\BLENDER_VERSION\scripts\addons\DTB\..". IM Uninstall removes that folder and the re-install puts it in "C:\Users\User\AppData\Roaming\Blender Foundation\Blender\2.92\scripts\addons\DTB\.."
Ok, I did a little adjusting here. I got it working, this is how I did it.
First, copy the DTB folder from your directory :
C:\Users\YourUsername\AppData\Roaming\Blender Foundation\Blender\2.91\scripts\addons
And put it in
C:\Users\YourUsername\AppData\Roaming\Blender Foundation\Blender\2.92\scripts\addons
You may need to make the folder scripts and also addons to put the DTB folder into.
Then it should come up.
I found my problem. I used scnenes that i created on my old pc. If i use new ones, the bridge is working. I dont now why but finally it works. But i think it helps no one here.
