Ron's Fog etc.
vindazivindazi Posts: 671
Has anyone used Ron's fogs and smoke? Is it possible to use it in Daz or Bryce, or just Photoshop? If not is there any way to get that in Daz?
  • adamr001adamr001 Posts: 1,322
    You can create images with them that you can use in DAZ or Bryce, but they are really just photoshop brushes (which can also be used in Gimp with a little effort).
  • vindazivindazi Posts: 671
    Is there a way to add that type of 3D fog that would be, or have the characteristics of an obj file?
    You could use the brushes to make diffuse and transparency maps that you could apply to a planar primitive.
  • PendraiaPendraia Posts: 3,636
    If you want ready made 3d fog there is Age Of Armours camera shaders...which do a fog effect or jepes has a fog prop in daz's store.
  • Zev0Zev0 Posts: 7,123
    There are some fog freebies at sharecg.
    download this to see how its done and just modify to your liking
    http://www.sharecg.com/v/49331/browse/11/Poser/Multi-plane-Fog-Tool
  • SkirikiSkiriki Posts: 4,976
    RDNA also has freebie weather effects; even if they are intended for Poser, I found out that they work just fine in DAZ too.
