G2F Hair Problem
dakkuuandakkuuan Posts: 305
I did a quick search on the forum and couldn't find anything about it, but I'm wondering if anyone has come up with a fix for the Genesis 2 issue with hair from previous generations. I've included a shot where I've found it most problematic (Valen's Hair). Now I'm sure most people just parent it to the head when it comes to this kind of issue, but I've had a difficlut time getting it to lay on the figure' chest correctly. Since this is an autofit problem, I'm sure there isn't a solution, but I thought I would ask anyway.
  • fixmypcmikefixmypcmike Posts: 19,702
    Select the hair and make sure "Show Hidden Parameters" is enabled on the Parameter tab options menu (rectangle with horizontal lines in the upper corner). Click on "Currently Used" and you should see the autogenerated morphs. If you aren't sure which one is causing the problem, try zeroing them one by one until you find the culprit.
  • dakkuuandakkuuan Posts: 305
    edited September 2014
    Yeah it was a morph. Unfortunately it's one that's pivitol to the character, my conversion of one of AMR's Genesis Proportion morphs. I lack Gen X so I had to do it the old fashion way. Without it, the hair hangs in mid air. I might have to set up Genesis for the size I want and go through each node documenting the scale to properly get her to scale, without causing weird effects with the hair.
    Post edited by dakkuuan on
  • almahiedraalmahiedra Posts: 1,366
    Valen's in G2F Parent + Collision works
    833 x 805 - 373K
    1.- Without collision
    2.- Collision with G2F (parent hair to G2F, next smooth modifier on hair and set collision to G2F)
    3.- Collision with G2F works until you use some clothes.
    4.- Using Sickle Super Clip Fixer. Now collision target is SY SCF with torso uper morphs dialed.
    5.- SY SCF isn't visible.
    707 x 805 - 379K
    707 x 805 - 323K
    707 x 805 - 381K
    707 x 805 - 330K
    707 x 805 - 328K
    I got it to cooperate with the included morphs, there was one I didn't notice that really made the difference.
    1000 x 1414 - 683K
