Andrey Pestryakov's Secluded Island crashes 4.14
richardandtracy
I have recently bought Andrey Pestryakov's Secluded Island https://www.daz3d.com/secluded-island and found every time I tried rendering in iRay in 4.14 it crashed DS. Every single time without exception. I have never before had DS crash.
After trying to see memory usage (12 GB out of 16, so OK and CPU OK too), setting optimization to memory etc, nothing prevented crashes. I was beginning to think of returning it, but there was one last thing to try. I tried a copy of 4.12 I have on the machine, and it worked perfectly. In fact, I couldn't get it to crash.
Has anyone any idea why the crash happened in 4.14 and how I could prevent it in 4.14? What could do it?
Regards,
Richard.
Post edited by richardandtracy on
There has been some previous threads about it - so maybe it isn't fixed.
I can't remember if that is that case when there was something with the hut that is causing the crash.
I tried it with 4.14: I had a crash, too.
It worked fine using 4.15!
It works in 4.15.0.2 for me too. There were soem chnages to various bricks in Shader Mixer, reflecting changes in Iray, where Daz had to implement their own shader code for things that had previously been built in functions - the issue may be from a stage during that process.
@richardandtracy "I have now installed DS 4.15, and it works. Unlike 4.12, it doesn't render in GPU"
Studio 4.15 has a minimum Nvidia driver requirement. You may need to update the driver.
