High quality makeup options overlay
Khoyan
I'd love to see some high quality, different styles of face makeup layer options that will go over whatever skin I'm using for Genesis 8/8.1 Females. Often I'll get a model for the morphs and the base skin, but the variations in makeup options will be quite limited (see Twosret 8 or Millawa 8) to a certain style.
I've tried finding something along those lines in the shop, but since the Daz shop has the most atrocious and horrifically user unfriendly interface, I've not been able to find anything.
Do you know of a product that fits with what I'm describing? Please link it! :)
Post edited by Khoyan on
There are a few in the store and they use the LIE tech in DS, although don't know of any that are 8.1 specific. If you search key words, chances are good to find products. try one of these
https://www.daz3d.com/essential-makeup-for-genesis-8-female
https://www.daz3d.com/ultra-bright-makeup-for-genesis-8-female
https://www.daz3d.com/l-i-e-make-up-set-2-for-genesis-3-female-s
https://www.daz3d.com/chinese-make-up
Thank you! The first one is very interesting. The ultra bright and chinese makeup options are too specific, though very interesting in themselves.
Would the one for G3 work on G8 and sit right? Do you have experience using these on newer core models? I know from before that there were some pretty good makeup options like this for G3, which I used to use then, but with the new generation, I'm working only with G8s now :)
I personally don't have any of those products since i usually just add my own makeup on the diffuse texture in photoshop if i need something specific. Since skins are pretty much interchangable between G8 and G3, you should be able to use the LIE presets on either one.
Sickleyield also has one: https://www.daz3d.com/fsl-ultimate-layered-shimmer-makeups
