Adding to Cart…
Now, thanks to Philemo, the OSX 64 bit version is available !
https://www.sharecg.com/v/88725/browse/9/Plug-in/LightX
Try as I might, I can't get my renders to look like yours. I particularly like the effect of the lights on the Lampshades and tables. Could you share your shader setup for the shades and also the bulb settings? Or am I out of line in asking?
Muchas gracias Alberto. Just downloaded... will give it a go.
I'm glad to help you, ProPose. In the images you can see the setting of the shaders, the two BulbLighX (instead normal bulb) and an extra normal distant light (this one is to simulate some indirect lightning). I changed the setting of the sky a little, turn off ambient light and applied Gamma correction to 2.2 in rendering. The other settings are untouched from the original.
¡De nada, Wgdjohn!
That's great!!! Thank you!!!
Fantastic! Wow, looky what I just found!!!
Thank You!!! :)
You're welcome !
And there is more to come !
Really? More to this plugin, or something else?
No! Don't tell me... Let it be a surprise!
Ooh, the suspense!
I want to use this So Bad! Time is never my pal, however, and the settings are So Vastly different from Standard Carrara that I just can't wrap my head around it without reading a manual - so I'll have to find some time (maybe?) to read the manual for ideas.
Perhaps if someone who understands how these things works could (perhaps?) put up some presets for the Browser, it could make the whole system more understandable.
I do know that, if I unlock the power of these lights, I intend to do just that - offer up some presets!
Edit: Along with a video tutorial!
Nice! thank you
You're welcome!
Maybe the demos I attached could be helpful. Change the .txt extension to .car
Anyway, let me know if you have doubts about the plugin.
Thank you! I'll give them a try!
.. nothing you have seen , will prepare you for the ending (: giggls
