Certain dForce products missing the dForce Modifier
I sometimes come across this in some of the products here at Daz. The items are advertized as dForce, and while most of the items have that modifier, some don't. Now, they have the option (i.e. they have the 'simulation' tab inside the parameters) to simulate, but Daz throws out an error stating there's no dForce items in the scene. How can I rectify this, if at all possible? And if there are other products that you may know of that have this problem, then please state them here. How do they not notice when in QA mode?
  • mr clammr clam Posts: 707
    edited May 2021
    It's easy enough to add a modifier, but you need to burrow down a bit. You can use this to add dForce to items that have no dForce Modifier.
    Select the item you want to dForce in the scene. Then, in the Menu, go to:
    Edit>Object>Geometry>Add dForce Modifier: Dynamic Surface
    Post edited by mr clam on
    Many products advertised as dForce will actually only have dForce on some of the items in the product.
  • SeraSera Posts: 1,675
    "dForce Lounge Wear" doesn't move at all when it's simulated, even though it does have a dforce modifier applied. I don't know why. I looked over the settings briefly and found nothing that could explain it. I was in a hurry that day, so I just used mesh grabber instead.
    if i get the error and it has a df modifier i delete it then add another.
